Curves workbench
Vincent B
Re: Curves workbench
Post by Vincent B »
drmacro wrote: Mon Apr 12, 2021 7:20 pm
GlouGlou wrote: Mon Apr 12, 2021 6:50 pm Blend surface: how to get more profiles? :cry:
Rail samples property?
no, profile property seems not working.
drmacro
Post by drmacro »
GlouGlou wrote: Mon Apr 12, 2021 7:21 pm
um...I'm in 0.20 ATM, seems to work there.
Chris_G
Post by Chris_G »
The "Profile Samples" property is unused.
I think I used it to generate a point array, to build an interpolating surface.
Now that we have Gordon Surface, this is unused.
I should hide this property.
Chris_G
Post by Chris_G »
GlouGlou wrote: Mon Apr 12, 2021 7:20 pm Blend Curve small bug: reversed mode doesn't work with a 0 parameter. Then it's not possible to get the opposite side of edge.
I'll have look. Thanks.
drmacro
Post by drmacro »
Chris_G wrote: Mon Apr 12, 2021 8:46 pm
but...when I increased it, it increased the number of "ribs" in @Glouglou's example file? :?
Chris_G
Post by Chris_G »
drmacro wrote: Mon Apr 12, 2021 8:48 pm but...when I increased it, it increased the number of "ribs" in @Glouglou's example file? :?
Rail Samples controls the number of generated Blend curves along the 2 rails
Profile Samples is now unused.
drmacro
Post by drmacro »
yes, I was using Rail samples. :oops:
Vincent B
Post by Vincent B »
Chris_G wrote: Mon Apr 12, 2021 8:46 pm The "Profile Samples" property is unused.
It's a shame to not keep that feature anymore, gordon doesn't have continuity parameters.
Chris_G
Post by Chris_G »
GlouGlou wrote: Tue Apr 13, 2021 4:41 pm It's a shame to not keep that feature anymore, gordon doesn't have continuity parameters.
Only the "Profile Samples" property is deprecated.
Not the whole BlendSurface tool.
As far as I can remember, before Gordon surface, both "Profile Samples" and "Rail Samples" were used to compute a array of points on the BlendSurface, and those points needed to be approximated or interpolated with another tool.
With Gordon surface added, I only needed to generate a curve network (= the 2 rails + a series of blend curves) to feed the Gordon tool, hence deprecating the "Profile Samples" property.
Vincent B
Post by Vincent B »
You right, its possible to use a gordon with a blendsurface. So, the continuity of a gordon can be adjusted like this. ;)
