Curves workbench
drmacro
Re: Curves workbench
Post by drmacro »
In the attached file I have create two curved pipes using a Freehand BSpline.
The spline itself passes geometry check. I have done the pipe with both a multi-profile Part Sweep and a Curves PipeShell. The Sweep cause the sweep profile to rotate around the spine, causing a very wonky seam line. The PipeShell behaves much better.
But, both the Sweep and the PipeShell fail geometry check. Both show the seam line (Edge1 in each) with a BOPAlgo GeomAbs_C0. Both also show the face of the solid with the same error.
Is there settings or can the constituent objects be changed to remedy this?
Snip macro screenshot-6b923a.png (209.51 KiB) Viewed 1812 times
Example-1.FCStd
(577.13 KiB) Downloaded 32 times
I get the wonky seamline only with the Frenet option set, without it looks quit normal. However, even without Frenet it shouws the CheckGeometry errors.
drmacro
Post by drmacro »
Apparently Curves Shapes, Curves and FC 0.20 don't really get along well ATM...
I tried removing and reinstall, same...
12:46:45  Traceback (most recent call last):
  File "/home/mac/.local/share/FreeCAD/Mod/CurvedShapes/CurvedArray.py", line 196, in onChanged
    self.execute(fp)
  File "/home/mac/.local/share/FreeCAD/Mod/CurvedShapes/CurvedArray.py", line 179, in execute
    self.makeRibs(prop)
  File "/home/mac/.local/share/FreeCAD/Mod/CurvedShapes/CurvedArray.py", line 114, in makeRibs
    if (obj.Surface or obj.Solid) and obj.Items > 1:
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'Surface'
12:46:45  16Standard_Failure Need at least two vertices, edges or wires to create loft face
12:46:45  Creation of surface is not possible !
12:46:45  <Part> ViewProviderExt.cpp(1306): Cannot compute Inventor representation for the shape of sink#CurvedArray: Bnd_Box is void
    self.execute(fp)
    self.makeRibs(prop)
12:46:45  <Part> ViewProviderExt.cpp(1306): Cannot compute Inventor representation for the shape of sink#CurvedArray001: Bnd_Box is void
12:46:45  AttachEngine3D::calculateAttachedPlacement:InertialCS: inertia tensor has axis of symmetry. Second and third axes of inertia are undefined.
12:53:21  Traceback (most recent call last):
  File "/home/mac/.local/share/FreeCAD/Mod/Curves/./freecad/Curves/parametricSolid.py", line 97, in onDocumentRestored
    fp.setEditorMode("ShapeStatus", 1)
<class 'AttributeError'>: Property container has no property 'ShapeStatus'
  File "/home/mac/.local/share/FreeCAD/Mod/Curves/./freecad/Curves/parametricSolid.py", line 112, in getIcon
    return self.icons[self.Object.ShapeStatus]
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'ShapeStatus'
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.20.26829 (Git)
Hash: 175ceb2d12e69c81017fbb34c4e20d9eaa4fd5cc
Python version: 3.7.3
Qt version: 5.11.3
Chris_G
Post by Chris_G »
drmacro wrote: Sat Jan 01, 2022 2:04 pm Is there settings or can the constituent objects be changed to remedy this?
Unfortunately no, I don't think.
But BOPAlgo GeomAbs_C0 errors should be safe as long as you don't use the surface for Thickness or 3DOffset operations.
drmacro wrote: Sat Jan 01, 2022 5:52 pm Apparently Curves Shapes, Curves and FC 0.20 don't really get along well ATM...
You have some parametricSolid objects in your document that were made with an older version of CurvesWB.
This should fix it :
for o in App.ActiveDocument.Objects:
    if hasattr(o, "Proxy") and ("parametricSolid" in o.Proxy.__repr__()) and not hasattr(o, "ShapeStatus"):
        o.addProperty("App::PropertyString", "ShapeStatus", "Solid", "Status of the created shape")
drmacro
Post by drmacro »
Chris_G wrote: Sat Jan 01, 2022 6:47 pm
Thanks I'll give it a go.
Just for clarity, the errors were on other files, not this one.
drmacro
Post by drmacro »
Hmm...loaded an offending file, ran the code, closed/opened file:
Edit: it appears to work on some files.
14:19:23  Traceback (most recent call last):
    self.execute(fp)
    self.makeRibs(prop)
14:19:23  16Standard_Failure Need at least two vertices, edges or wires to create loft face
14:19:23  Creation of surface is not possible !
14:19:23  <Part> ViewProviderExt.cpp(1306): Cannot compute Inventor representation for the shape of sink#CurvedArray: Bnd_Box is void
    self.execute(fp)
    self.makeRibs(prop)
14:19:23  <Part> ViewProviderExt.cpp(1306): Cannot compute Inventor representation for the shape of sink#CurvedArray001: Bnd_Box is void
14:19:23  AttachEngine3D::calculateAttachedPlacement:InertialCS: inertia tensor has axis of symmetry. Second and third axes of inertia are undefined.
This is the 2nd file where it didn't work. The 1st was past forum limit.
SurfaceTo3Pipes.FCStd
(533.08 KiB) Downloaded 24 times
onekk
Post by onekk »
Some scriptability tests of Curves WB, the code is working if you have correctly installed the AddOn.
I'm stating from this post.
https://forum.freecadweb.org/viewtopic. ... 27#p334527
Sadly this example will not work anymore, as something has changed in sources, so I have slightly modified some calls.
The relevant code is in:
https://forum.freecadweb.org/viewtopic. ... 70#p325870
# Create the Gordon surface
gordon = freecad.Curves.gordon.InterpolateCurveNetwork([bs0,bs1,bs2],[bs3,bs4,bs5],0.1,0.001)
Part.show(gordon.surface().toShape())
DOC.recompute()
And leveraging some more the code present in Curves WB, I have obtained to make this code work, to show combs.
FreeCADGui.Selection.clearSelection()
s = FreeCADGui.Selection.addSelection(obj5, "Edge1")
comb_obj = freecad.Curves.ParametricComb.ParametricComb()
comb_obj.Activated()
s = FreeCADGui.Selection.addSelection(obj4, "Edge1")
comb_obj1 = freecad.Curves.ParametricComb.ParametricComb()
comb_obj1.Activated()
Sadly if freecad.Curves.ParametricComb.ParametricComb() will have a more direct mean to assign the curve to show it will be a very good thing.
Hope it will help to spread the use of Curves WB.
Regards
Carlo D.
- Various other stuffs.
Chris_G
Post by Chris_G »
With this commit, the Comb Activated() command returns the created FeaturePython object.
So you can now do :
comb_fp = comb_obj.Activated()
# Change Comb target
comb_fp.Edge = (obj4, "Edge1")
onekk
Post by onekk »
Chris_G wrote: Wed Jan 12, 2022 3:25 pm With this commit, the Comb Activated() command
Many thanks, for the reply.
A part for the usual consideration, your WB is Experimental.
How stable is the interface.
I can't get an idea, as I've read almost all the 113 pages of this thread, so "Sweep to 2 Rails" seem to be deprecated in favour of "gordon surfaces",
One thing I'm missing is some customisation about the GeomInfo as they are not very readable.
Would it to be possible to add a GeomFontString to choose the font and maybe the color of the diaplyed info, or maybe something similar to these lines:
	    f_name = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Curves").GeString('GeomInfoFontString', "FreeMono,FreeSans,sans")
	    self.myFont.name = f_name
            size = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Curves").GetInt('GeomInfoFontSize', 14)
            print(size)
            self.myFont.size.setValue(size)
            self.SoText2 = coin.SoText2()
            self.SoText2.string = ""  # "Nothing Selected\r2nd line"
            pref_col = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Curves").GetString('GeomInfoFontColor', "0,0,0")
            color = tuple([float(x) for x in pref_col.split(',')])
            self.color = coin.SoBaseColor()
            self.color.rgb = color
Many thanks for your work and Best Regards.
Carlo D.
drmacro
Post by drmacro »
Just note, in case someone else attempts to use Curves on Manjaro.
With the latest updates on Manjaro that installs Python 3.10 Curves is definitely broken.
I've not found the secret to adding another version of Python to Manjaro.
I guess it breaks pivy as well.
The Arch User Repository for freecad-git fails to complete the install as well, failing a bunch of test suite.
I have only been looking at Manjaro for a couple weeks, and am far from comfortable with this OS at this point.
So, there may be a simple fix or tweak to make it work...
