Curves workbench
onekk
Re: Curves workbench
Post by onekk »
One possibility is to use some conda environment on which you choose all packages on it, or maybe expand an AppImage and run from the expanded directory, (That is a sort of miiniconda environment).
Sadly with Arch Linux you are many time "one step ahead" many program development in terms of update libraries.
This is sometimes difficult to cope with, as sometimes more "stability is needed", but is somewhat an "egg chicken" dilemma.
Regards
Carlo D.
- Various other stuffs.
drmacro
Post by drmacro »
onekk wrote: Wed Jan 12, 2022 4:08 pm One possibility is to use some conda environment on which you choose all packages on it, or maybe expand an AppImage and run from the expanded directory, (That is a sort of miiniconda environment).
Regards
Carlo D.
Yes, luckily, my main PC is Debian and I don't have to make it work on Manjaro. So, I can wait for the catch-up. ;)
onekk
Post by onekk »
drmacro wrote: Wed Jan 12, 2022 4:12 pm Yes, luckily, my main PC is Debian and I don't have to make it work on Manjaro. So, I can wait for the catch-up. ;)
You have two distribution, almost at the opposite ends.
Debian is almost conservative and patch heavily upstream sources to adapt them to his Policy
Manjaro (Arch Linux) is very "bleeding edge" and patch upstream sources "less as possible".
Both use systemd so are out of my "personal tastes".
But this is OT here.
Regards
Carlo D.
Chris_G
Post by Chris_G »
drmacro wrote: Wed Jan 12, 2022 3:54 pm Just note, in case someone else attempts to use Curves on Manjaro.
With the latest updates on Manjaro that installs Python 3.10 Curves is definitely broken.
Yes Pivy, is broken with python 3.10
But I have pushed a fix on monday, that allows Curves WB to load normally, but some tools of the workbench that use pivy will still be broken ...
onekk
Post by onekk »
Hello Chris_G
A little explanation.
poles0 = [Vector (0.0, 0.0, 0.0), Vector (0.16666666666666666, 0.0, 0.20000000794728598), Vector (0.49999999999999994, 0.0, 0.40000001589457196), Vector (0.8333333333333334, 0.0, 0.20000000794728598), Vector (1.0, 0.0, 0.0)]
weights0 = [1.0, 1.0, 1.0, 1.0, 1.0]
knots0 = [0.0, 0.5830951956177974, 1.1661903912355949]
mults0 = [4, 1, 4]
periodic0 = False
degree0 = 3
rational0 = False
bs0 = Part.BSplineCurve()
bs0.buildFromPolesMultsKnots(poles=poles0, mults=mults0, knots=knots0, periodic=periodic0, degree=degree0, weights=weights0, CheckRational=rational0)
obj0 = FreeCAD.ActiveDocument.addObject("Part::Spline","BSplineCurve0")
obj0.Shape = bs0.toShape()
from this line:
and from:
mults0 = [4, 1, 4]
I could guess that with buildFromPolesMultsKnots I could create NURBS curves?
obviously giving weights different from 1.0
according to:
https://en.wikipedia.org/wiki/Non-unifo ... l_B-spline
I could associate mults0 (in this case) to the weight in the page, so what is weights0, that appear to be weights applied to "interpolation points".
Or probably I have not guess the entire argument.
TIA and regards.
Carlo D.
onekk
Post by onekk »
Another little question:
I have added some code to the gordon example above:
poles6 = [
    Vector (0.16666666666666666, 0.0, -0.20000000794728598),
    Vector (0.49999999999999994, 0.0, -0.40000001589457196),
    Vector (0.90, 0.0, -0.20000000794728598),
weights6 = [1.0, 1.0, 1.0, 1.0, 1.0]
knots6 = [0.0, 0.5830951956177974, 1.1661903912355949]
mults6 = [4, 1, 4]
bs6 = Part.BSplineCurve()
bs6.buildFromPolesMultsKnots(poles=poles6, mults=mults6, knots=knots6, periodic=False, degree=3, weights=weights6, CheckRational=False)
obj6 = FreeCAD.ActiveDocument.addObject("Part::Spline","BSplineCurve6")
obj6.Shape = bs6.toShape()
poles7 = [
    Vector (0.013121589026499694, 0.7915876947955887, -0.0008571221601094414),
    Vector (-0.00885599845935274, 0.7914868593215942, -0.40897222572543346),
    Vector (0.06419121554803943, 0.7914868593215942, -0.9506049970258048),
    Vector (0.4267428298127499, 0.7914868593215942, -0.5416327713003715),
    Vector (0.7273027300834656, 0.7914868593215942, 0.0)
weights7 = [1.0, 1.0, 1.0, 1.0, 1.0]
knots7 = [0.0, 0.7053976507426758, 1.6396089746603792]
mults7 = [4, 1, 4]
bs7 = Part.BSplineCurve()
bs7.buildFromPolesMultsKnots(poles=poles7, mults=mults7, knots=knots7, periodic=False, degree=3, weights=weights7, CheckRational=False)
bs7.getKnots()
obj7 = FreeCAD.ActiveDocument.addObject("Part::Spline","BSplineCurve7")
obj7.Shape = bs7.toShape(bs7.FirstParameter, bs7.LastParameter)
poles8 = [
    Vector (-0.29265061020851135, 1.7891597747802734, 0.0),
    Vector (0.556077287533451, 1.7891597747802734, -0.7004100558512543),
    Vector (1.2192605936714151, 1.7891597747802732, -0.9304442719319388),
    Vector (1.2656674010425126, 1.7891597747802734, -0.23003421608068433),
    Vector (1.2394413948059082, 1.7891597747802734, 0.0)]
weights8 = [1.0, 1.0, 1.0, 1.0, 1.0]
knots8 = [0.0, 1.5852100266723423, 2.105837254626154]
mults8 = [4, 1, 4]
bs8 = Part.BSplineCurve()
bs8.buildFromPolesMultsKnots(poles=poles8, mults=mults8, knots=knots8, periodic=False, degree=3, weights=weights8, CheckRational=False)
bs8.getKnots()
obj8 = FreeCAD.ActiveDocument.addObject("Part::Spline","BSplineCurve8")
obj8.Shape = bs8.toShape()
poles9 = [
    Vector (0.37568899989128113, 0.0, -0.2814561426639557),
    Vector (0.1979298550637957, 0.2528165565557051, -0.5073158012737045),
    Vector (0.012426622785748864, 0.8217413994502759, -0.8116662306235015),
    Vector (0.25350408566703514, 1.4418752936204768, -0.7220463662761115),
    Vector (0.5054633617401123, 1.7891597747802734, -0.5606870651245117)]
weights9 = [1.0, 1.0, 1.0, 1.0, 1.0]
knots9 = [0.0, 0.9339859674161192, 2.0140618136101445]
mults9 = [4, 1, 4]
bs9 = Part.BSplineCurve()
bs9.buildFromPolesMultsKnots(poles=poles9, mults=mults9, knots=knots9, periodic=False, degree=3, weights=weights9, CheckRational=False)
obj9 = FreeCAD.ActiveDocument.addObject("Part::Spline","BSplineCurve9")
obj9.Shape = bs9.toShape()
gordon1 = freecad.Curves.gordon.InterpolateCurveNetwork([bs6,bs7,bs8],[bs3,bs9,bs5],0.1,0.001)
Part.show(gordon1.surface().toShape())
wire1 = Part.Wire((bs6.toShape(), bs0.toShape()))
face1 = Part.Face(wire1)
Part.show(face1, "Face1")
wire2 = Part.Wire((bs2.toShape(), bs8.toShape()))
face2 = Part.Face(wire2)
Part.show(face2, "Face2")
shell = Part.Shell([face1, gordon, face2, gordon1])
Part.show(shell, "Shell")
DOC.recompute()
I have duplicated the some bspline to try to close a shell and create a solid, so I have taken z coordinates and simply negated them, leaving all the other bsplines untouched,
I was expecting that the shell will close, but I'm receiving an error of:
<class 'Part.OCCError'>: Shape is not a shell
What I'm doing wrong.
TIA and Regards.
Carlo D.
Chris_G
Post by Chris_G »
onekk wrote: Wed Jan 12, 2022 4:52 pm I could guess that with buildFromPolesMultsKnots I could create NURBS curves?
according to:
The weights are the 'w' coordinates of the poles, in rational BSplines.
In homogeneous coordinates, the poles are 4D : (x, y, z, w)
So you must always have : len(weights) = len(poles)
The mults are the repetition of the knots.
So you must always have : len(mults) = len(knots).
Most often in Nurbs articles, knots arrays are written WITH knot repetition.
In OpenCascade, the knots are described by 2 arrays : knots (without repetition) and mults.
So, a same BSpline knot sequence would be written either as :
knots = [0.0, 0.0, 0.0, 1.0, 2.0, 2.0, 2.0] # Traditional way
or :
knots = [0.0, 1.0, 2.0]
mults = [3, 1, 3] # OCC and FreeCAD way
Chris_G
Post by Chris_G »
onekk wrote: Wed Jan 12, 2022 3:49 pm A part for the usual consideration, your WB is Experimental.
How stable is the interface.
I can't get an idea, as I've read almost all the 113 pages of this thread, so "Sweep to 2 Rails" seem to be deprecated in favour of "gordon surfaces",
Gordon is much better and accurate, so it should be used first.
"Sweep to 2 Rails" should be considered deprecated for now.
onekk wrote: Wed Jan 12, 2022 3:49 pm One thing I'm missing is some customisation about the GeomInfo as they are not very readable.
Would it to be possible to add a GeomFontString to choose the font and maybe the color of the displayed info, or maybe something similar to these lines:
This is very old code again (as "Sweep to 2 Rails"), and I wouldn't code it that way now. It would probably need a full refactor.
But I'll consider adding your suggested customization options.
drmacro
Post by drmacro »
Chris_G wrote: Wed Jan 12, 2022 6:51 pm ...
Hmm...all those great tutorials from MangoJelly deprecated...that's a shame. ;)
Does Gordon really replace approximate points to Nurbs?
drmacro
Post by drmacro »
When using the freehand bspline there is the x,y,z axis constraint.
I'm not getting what I'd expect from it...probably because I'm using it wrong. :roll:
What is the proper workflow?
Does one hold down the z key while moving vertex? This does not seem to constrain and the cursor flashes at the rate of the key repeat while moving the vertex.
Clicking the vertex, hit z key doesn't seem to constrain.
Instructions please. :mrgreen:
