Curves workbench
kartuche
Re: Curves workbench
Post by kartuche »
Chris_G wrote: Sat Mar 20, 2021 9:28 am The Mapped_Sketch must be attached to the target face (through the Support property, MapMode has no incidence)
The geometries that must be mapped on the target face in the Mapped_Sketch must be contained in a blue Construction rectangle that represent the face bounding box.
I've done everything Chris wrote and I'm still having trouble to get SketchOnSurface work for me.
Simple shapes, sketch of a circle contained in a blue rectangle. This appears:
20:23:11  Traceback (most recent call last):
  File "C:\Users\user\AppData\Roaming\FreeCAD\Mod\Curves\Sketch_On_Surface.py", line 244, in execute
    if i.Construction and not obj.ConstructionBounds:
<class 'AttributeError'>: 'Part.LineSegment' object has no attribute 'Construction'
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL)
example.FCStd
(11.42 KiB) Downloaded 40 times
Chris_G
Post by Chris_G »
Please update Curves WB first.
kartuche
Post by kartuche »
Chris_G wrote: Sat Apr 10, 2021 8:24 pm Please update Curves WB first.
Thank you. Works like charm now.
drmacro
Post by drmacro »
FYI
Mads Leth Danielsen has a new video for that. :mrgreen:
The volume is low, but, as always great content.
https://youtu.be/z7vgMzuGT2c
drmacro
Post by drmacro »
Curves WB SVG
The SVG tool says it does something with the svg data on the clipboard.
How does one get the SVG data on the clipboard?
What does it do with the SVG where does it paste said data?
I tried to open an svg and copy it in another FC document to no avail.
Chris_G
Post by Chris_G »
This tool is useful when working with FC and Inkscape in parallel :
Open Inkscape
Ctrl-C some objects
Switch to FC
Use Curves->PasteSVG tool
The Inkscape objects in clipboard are inserted.
Post by Kunda1 »
Chris_G wrote: Sun Apr 11, 2021 9:19 pm This tool is useful when working with FC and Inkscape in parallel :
Open Inkscape
Ctrl-C some objects
Switch to FC
Would be great to add to Curves_PasteSVG.
Are their any limitations with it?
Also is it scriptable?
Vincent B
Post by Vincent B »
Blend surface: how to get more profiles? :cry:
aa.FCStd
(79.94 KiB) Downloaded 42 times
drmacro
Post by drmacro »
GlouGlou wrote: Mon Apr 12, 2021 6:50 pm Blend surface: how to get more profiles? :cry:
Rail samples property?
Vincent B
Post by Vincent B »
Blend Curve small bug: reversed mode doesn't work with a 0 parameter. Then it's not possible to get the opposite side of edge.
