Great master piece of surface handling!
Curves workbench
Re: Curves workbench
What is wrong with the blendCurve for that purpose ?
But the shark stays !
Can't use blend curve, but some extrudes.
- slope2.FCStd
- (79.19 KiB) Downloaded 42 times
Hello Community,
I am creating a BSplineSurface using the Gordonssurface function from Curves Workbench.
If I create my u- and v-lines as Draft.Bsplines only, the Gordonssurface is created as expected. However, if I insert a Draft.line between points 34 and 33, for example, and connect it to the BSplines via points 30-33 and 34-38 using Draft.upgrade to form a wire (new u-line) and then create the Gordonssurface, I get the error that the Gordonssurface no longer matches the specified outer contour.
I have no problems with this on another test object.
Pictures / files are attached. Maybe one of you knows where my error is.
Greetings
PS: Yes I have to use this outdated version but with the newest version it doesn't work either.
OS: Windows 10 (10.0)
Version: 0.18.16146 (Git)
Branch: (HEAD detached at 0.18.4)
Python version: 3.7.3
Qt version: 5.12.5
Greetings
Qt version: 5.12.5
- Surface_normal.FCStd
- (392 KiB) Downloaded 44 times
- Surface_mit_Linie_und_Fehler.FCStd
- (394.7 KiB) Downloaded 39 times
- Test_mit_Linie_fehlerfrei.FCStd
- (62.45 KiB) Downloaded 41 times
I don't know why the GordonSurface tool seems to miss Point 38.
As a workaround, I managed to get a working surface by inserting a BlendCurve between each blue InterpolationCurve (but can probably be Draft.BSpline as well) and the Line Segment.
The 5 segments are then joined into a single BSpline Curve, with joinCurve tool.
If you need Points 33 and 34 to be sharp, you can lower the Continuity2 property of the BlendCurves to C0.
- Surface_with_blendcurves.FCStd
- (241.43 KiB) Downloaded 38 times
This sketch gives a joincurve error.
- JoinCurve_bug.FCStd
- (6.55 KiB) Downloaded 43 times
How did you double the subshapes ?
o1.Edges
# >>> [(<Sketcher::SketchObject>, ('Edge3', 'Edge3', 'Edge2', 'Edge2', 'Edge1', 'Edge1'))]
I can't do that. just selected edge by edge.
(Curves wb re download just few minutes ago)
- Capture.JPG (60.63 KiB) Viewed 1899 times
I'm trying to export a STEP file of a eccentric piping reducer in a pipe system for use in a CFD model. I think the BlendSolid function is the best way to model an reducer in freeCad with the continuity scales. To give a better understanding, I'm essentially trying to do what is being done in this AutoCAD youtube tutorial at time stamp of 7:25 to 7:30
https://youtu.be/Urzqrb9YLiU
My question is: What is the range of continuity scale? It appears to be from 0 to 5, as if I type in 6 it looks the same as 5.
Also, would anyone care to guess what value of continuity is close to a real piping reducers? I'm guessing 5/5.
Thanks!
Louis
Thanks!
Louis
This property is the continuity value (continuity of the derivatives) , from C0 to G5.
