Curves workbench
Re: Curves workbench
Click an axis key while you are dragging points (or blue lines between points) to enable / disable axis constraint.
Aha! That's what I was missing. I need to start the drag first then hit the axis key.
Thanks!
Hi, I wanted to know if there is a method to modify the BSplines created from surface edges or those created with other workbenches, for example like the Mesh Remodel.
Thanks and I hope to see more news in this useful Workbench with which I am creating complex surfaces.
Made with Curve
And here some others image created almost with Curve Workbench https://forum.freecadweb.org/viewtopic.php?f=24&t=64136
Made with Curve
No. Not yet.
I would need a good freehand mouse manipulation library.
I gave a try at pivy.graphics library (used in Freehand_BSpline / Splitcurve tools for example), but I am not totally satisfied with it.
I also gave a try at Pivy_Trackers but didn't managed to get what I was looking for.
Thanks,I hope you can find a way, since there is the command to create editable curves it would be nice to at least convert the curves in order to edit them like those of the Workbench Curve.
Hi I often encounter this problem when I try to Blend between two curves from edges generated by objects, as in this case, which is not successful in creating the curve.
float division by zero
20:12:45 Traceback (most recent call last):
File "/home/guest/.local/share/FreeCAD/Mod/Curves/freecad/Curves/ParametricBlendCurve.py", line 168, in onChanged
self.execute(fp)
File "/home/guest/.local/share/FreeCAD/Mod/Curves/freecad/Curves/ParametricBlendCurve.py", line 115, in execute
bc = self.compute(fp)
File "/home/guest/.local/share/FreeCAD/Mod/Curves/freecad/Curves/ParametricBlendCurve.py", line 98, in compute
c1 = blend_curve.PointOnEdge(e1)
File "/home/guest/.local/share/FreeCAD/Mod/Curves/freecad/Curves/blend_curve.py", line 48, in __init__
self.edge = edge
File "/home/guest/.local/share/FreeCAD/Mod/Curves/freecad/Curves/blend_curve.py", line 79, in wrapper
self.set_vectors()
File "/home/guest/.local/share/FreeCAD/Mod/Curves/freecad/Curves/blend_curve.py", line 73, in set_vectors
self.size = self._size
File "/home/guest/.local/share/FreeCAD/Mod/Curves/freecad/Curves/blend_curve.py", line 173, in size
self._scale = val / self._vectors[1].Length
<class 'ZeroDivisionError'>: float division by zero
self.execute(fp)
self.edge = edge
self.set_vectors()
self.execute(fp)
self.edge = edge
self.set_vectors()
20:12:45 Running the Python command 'ParametricBlendCurve' failed:
File "/home/guest/.local/share/FreeCAD/Mod/Curves/freecad/Curves/ParametricBlendCurve.py", line 680, in Activated
bc = obj.Proxy.compute(obj)
self.edge = edge
self.set_vectors()
- Ball-corner.FCStd
- (26.29 KiB) Downloaded 29 times
This is just a wild thought, so...
There is a macro in the Addon manager called Bevel. You might be able to modify it to handle ball ends like this...
But, I might be crazy.
Thanks, I found a solution about that, I think this i due to my Bspline that has only two CV, I added an other one in the middle and now seem working..
Sweep on 2 rails.
I need a hint.
Trying to generate the sweep surface I obtain errors.
Michel
I need a hint.
My configuration7:44:52 Proxy changed
17:44:52 Blending changed
17:44:52 ProfileSamples changed
17:44:52 RailSamples changed
17:44:52 Parametrization changed
17:44:52 Extend changed
17:44:52 Label changed
17:44:52 updateDate : Label
17:44:52 Change property: DisplayMode
17:44:52 updateDate : Birail
17:44:52 updateDate : Blending
17:44:52 updateDate : ExpressionEngine
17:44:52 updateDate : Extend
17:44:52 updateDate : Label2
17:44:52 updateDate : Parametrization
17:44:52 updateDate : Points
17:44:52 updateDate : ProfileSamples
17:44:52 updateDate : Profiles
17:44:52 updateDate : Proxy
17:44:52 updateDate : RailSamples
17:44:52 updateDate : Shape
17:44:52 updateDate : Visibility
17:44:52 Change property: Proxy
17:44:52 Birail changed
17:44:52 Profiles changed
17:44:52
Profile parameters :
0.0
1.0
17:44:52
0.0
0.0
17:44:52
Matrix 1
Matrix ((-1222.05,167.008,-0,611.027),(0,-2.6386e-13,-1,-2.66454e-13),(0,-1188.32,2.22045e-16,-1200),(0,0,0,1))
17:44:52
Matrix 2
Matrix ((1222.05,-167.008,-0,-611.027),(-0,-2.6386e-13,-1,-2.66454e-13),(-0,-1188.32,2.22045e-16,-1200),(0,0,0,1))
17:44:52
Profile : 0.000000 - 0.000000
17:44:52
Matrix 1
Matrix ((123.726,570.634,-0,1438.14),(-1.0253e-13,4.11693e-14,-1,-4.8356e-13),(-461.753,185.41,2.22045e-16,-2177.76),(0,0,0,1))
17:44:52
Matrix 2
Matrix ((-105.099,2500.13,-5.83444e-32,1537.2),(1.03258e-13,1.17763e-13,-1,-5.87252e-13),(465.033,530.358,2.22045e-16,-2644.75),(0,0,0,1))
17:44:52 Traceback (most recent call last):
File "C:\Users\miche\AppData\Roaming\FreeCAD\Mod\Curves\.\freecad\Curves\Sweep2Rails.py", line 49, in execute
s2r.setProfiles(self.setProfiles(obj.Profiles)) # ((e1,e2,e3))
File "C:\Users\miche\AppData\Roaming\FreeCAD\Mod\Curves\.\freecad\Curves\libS2R.py", line 139, in setProfiles
self.getLocalProfile(p)
File "C:\Users\miche\AppData\Roaming\FreeCAD\Mod\Curves\.\freecad\Curves\libS2R.py", line 175, in getLocalProfile
pro.localCurve1 = Part.Edge(c1, pro.FirstParameter, pro.LastParameter)
<class 'Part.OCCError'>: BRep_API: command not done
17:44:52 Recompute failed! Please check report view.
Thanks for your help,OS: Windows 10 (10.0)
Version: 0.20.26761 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
Locale: French/Canada (fr_CA)
Michel
Michel Sabourin (Sabm01)
www.simturb.com
www.simturb.com
Use Joincurve to build spline. Then the sweep on 2 rails works.
- sweep.FCStd
- (104.73 KiB) Downloaded 34 times
- Capture2.JPG (22.65 KiB) Viewed 1585 times
