Curves workbench
Re: Curves workbench
OK.
Please give a try with new v0.4.1
Still says 0.3.0 is installed, but the segment surface works as expected.
When creating a freehand b-spline why is snapping only allowed to other b-splines?
It would seem this is very limiting, since other geometry can't be used for reference.
Snapping should work for any geometry.
But the selection process during the BSpline editing is not working very well.
I agree the selection is a bit wonky.
I did think that the any vertex worked last I used it. But, today I noticed it was not. (And, I noted that my updates to the wiki on the use of the snap were updated to specifically say it would only snap to other b-splines.)
Also, is it possible to make a closed b-spline? Edit: still a question, but the JoinCurve does close the curve...
In the attached file the two b-splines loft ok, but because the ends just overlap (i.e. the XY coords of the start and end are the same) if fails geometry check. (At least I think that is the source of the error. It says Face1 has a selfintersect...but, I couldn't find Face1...)
Edit: scratch that. This file with the JoinCurves/loft fails geo. check.
- Trace_CurvesWB.FCStd
- (121.64 KiB) Downloaded 19 times
- Snip macro screenshot-93a0fe.png (51.72 KiB) Viewed 1588 times
Some nice videos with a few tips and ticks on surfacing (and few other things) in solidworks, but in general a lot of it can be useful to understand and do surfacing also in other programs...
https://www.youtube.com/c/lowe9/videos Andrew Lowe
https://www.youtube.com/c/DiMonteGroupInc/videos DiMonte Group Inc
Hi Chris,
I seem to be having the same problem drmacro had, I have V0.4.2 installed, regression?
The segmented surface problem that is.
TX Steve.
TX Steve.
OS: Manjaro Linux (XFCE/xfce)
Version: 0.20.28751 (Git) AppImage
Branch: (HEAD detached at 660655e)
Hash: 660655e54c97b5017ff0ac1e030059308cd4e3f5
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
* Curves 0.4.2
Previous fix was not good.
Problem should be fixed now, I hope, with v0.4.3
Thanks very much for the quick attention, works now.
Curves workbench: problems with MapSketchToSurface
I thought I had a good idea to solve this help request by using MapSketchToSurface.
This is what I tried to get equidistant marks on a spiral surface:
- create a spiral in Part workbench
- extrude the spiral in Part workbench to the width of the roll
- create a sketch with a rectangle, change it to construction geometry
- - set length=Spiral.Shape.Length
- - set width=Extrude.Length
- create the marks on the rectangle, I have used equidistant circles
- use Curves > MapSketchToSurface to map the sketch to the face
However, since it is a spiral where the inner diameter is smaller than the outer, the holes should not lie all on a straight line.
I'm not sure if I made something wrong or if I expect the wrong thing or if Curves is doing it wrong.
It would probably work, if I split the spiral and the sketches in chunks of 360°, but I wanted to avoid the calculations.
- MapOnSpiralSurface.FCStd
- (66.05 KiB) Downloaded 20 times
