Curves workbench
fc_tofu
Re: Curves workbench
Postby fc_tofu » Mon Apr 20, 2020 12:56 pm
hammax wrote:
Sun Apr 19, 2020 3:34 pm
… sorry fc_tofu, no retrieval. Too long ago.
Today I would do it in another way - and I have "only" FC.18.4.
Thank you.
I find @Chris_G's latest example of blend surface. "blendsurface.FCStd"
https://forum.freecadweb.org/download/f ... ?id=104829
My understanding is that,
The right tool to convert blender suface network into surface is Gordon surface, not Aproximation.
fc_tofu
Postby fc_tofu » Mon Apr 20, 2020 2:10 pm
freecad-heini-1 wrote:
Mon Apr 20, 2020 7:29 am
No, unfortunately I have not found a possibility but I have asked several times that we can make Gordon surfaces tangential to neighbouring surfaces.
You can call me Tofu, and many thanks for your explanation.
So basically I know, G1 Tide bottle is impossilbe with CurvesWB for now.
But I am still not very clear about the clause in your translated sentence.
"we can make Gordon surfaces tangential to neighbouring surfaces", is this a fact or a question?
freecad-heini-1
Postby freecad-heini-1 » Mon Apr 20, 2020 5:06 pm
It's a translation with:
https://www.deepl.com/en/translator
microelly2
Postby microelly2 » Wed Apr 22, 2020 4:00 pm
fc_tofu wrote:
Mon Apr 20, 2020 12:49 am
Thu Dec 14, 2017 3:37 pm
Hi, heini,
have you found a workaround to get a G1 surface Tide bottole?
Where I can get this model?
I want to see the reason why there is this trench.
clamped curves and surfaces must be smooth. https://pages.mtu.edu/~shene/COURSES/cs ... -type.html
I think there is a hard border which can be eliminated.
fc_tofu
Postby fc_tofu » Wed Apr 22, 2020 5:08 pm
Discussion:
https://forum.freecadweb.org/viewtopic ... &start=100
https://forum.freecadweb.org/viewtopic. ... 62#p204162
Sample file:
https://www.dropbox.com/s/5d4tbbjqalvwy ... fcstd?dl=0
https://forum.freecadweb.org/download/file.php?id=49055
This topic was posted in 2017, when @Chris_G told this is a limiation.
I am just curious, have some workaround been found during the last 3 years.
microelly2
Postby microelly2 » Thu Apr 23, 2020 10:14 am
To get a smooth border the tangents must be perpendicular to the mirror plane (yz).
I do this by given the 2nd and last but ones poles row the same y values as the first and last rows have.
The change is minimal but surfaceand mirror are now tangent.
here the model and the script
tide_bottle3_mod.fcstd
(106.34 KiB) Downloaded 9 times
f=App.ActiveDocument.Approximastion_Curve.Shape.Face1
c=f.Surface
poles=c.getPoles()
uk = c.getUKnots()
mu = c.getUMultiplicities()
ud = c.UDegree
uperiodic = c.isUPeriodic
vk = c.getVKnots()
mv = c.getVMultiplicities()
vd = c.VDegree
vperiodic = c.isVPeriodic
poles=c.getPoles()
polesa=np.array(poles)
polesb=polesa.swapaxes(0,1)
# polesb=np.round(polesb,1)
polesb[1,:,1]=polesb[0,:,1]
polesb[-2,:,1]=polesb[-1,:,1]
polesc=polesb.swapaxes(0,1)
sf=Part.BSplineSurface()
sf.buildFromPolesMultsKnots(polesc,mu,mv,uk,vk,False,False,ud,vd)
a=FreeCAD.ActiveDocument.getObject("ShapeA")
if a is None:
	a=FreeCAD.ActiveDocument.addObject("Part::Feature","ShapeA")
a.Shape=sf.toShape()
fc_tofu
Postby fc_tofu » Thu Apr 23, 2020 4:21 pm
I donn't know coding, but I know this is a cheerful workaround and deserves a celebration.
Thank you.
microelly2
Postby microelly2 » Thu Apr 23, 2020 6:54 pm
Thank you.
You can do it by design of the rib sketches without coding: the endings of the arcs must be perpendicular to the yz plane.
fc_tofu
Postby fc_tofu » Fri Apr 24, 2020 10:36 am
In your way, I can got a G1 mirrored surface now. Thank you!
Another question. If you check mirrored surface in "Object Property >View > Lighting = One Side", you will find Mirror command (both PartWB and DraftWB) donnot correct surface normal.
So, after Boolean Union, we finally get a polysurface with adjacent reversed normal. But it looks weird.
In this case, PartWB >Reverse shape can be used before Union command to get consistent normals between adjacent faces.
But "Reverse shape" command is crappy for now, it can only handle objects which LCS loates at world origin.
https://forum.freecadweb.org/viewtopic. ... 78#p384478
So, just be careful.
microelly2
Postby microelly2 » Fri Apr 24, 2020 11:18 am
The better way to create such volumes (tubes) is to see them as variant of a torus.
ribs are closed and the surface is cyclic in both directions.See an example here.
https://youtu.be/sWlaE4i2MAQ
There is no need of mirror and normalizing faces.
