Curves workbench
drmacro
Re: Curves workbench
Postby drmacro » Sat Oct 17, 2020 1:13 pm
GlouGlou wrote:
Sat Oct 17, 2020 12:54 pm
MixedCurve carry out a curve with curvature on U on V. So, the sweep is turning around the path. (use comb to see that)
But if you set Angular deflection = 10 or less and deviation 0,1 or less for the sweep, the pipe look like nice. ;)
Yes, I did see that with the comb. Thanks.
Interestingly, if you change the sweep profile to a hexagon, the surface is smoother than with a circle...
My beginners, written treatise: Learning FreeCAD
GlouGlou
Postby GlouGlou » Sun Oct 25, 2020 9:24 am
Proposal for new feature:
a sweep with 2 points (or more) and the path. There are not tool to do that directly in freecad I guess.
Could be an possibility for PipeShell?
sweeppoints.FCStd
(8.15 KiB) Downloaded 7 times
GlouGlou
Postby GlouGlou » Sun Oct 25, 2020 10:11 am
use a cloud point (point wb) to make a surface with "Approximate to Nurbs" as a birail cloud.
Pauvres_honteux
Postby Pauvres_honteux » Wed Oct 28, 2020 7:02 am
a sweep with 2 points (or more) and the path. Could be an possibility for PipeShell?
Trying to wrap my head around your proposal and got to this (probably wrong) conclusion:
the purple curve shall somehowe be extruded and be made to pass through a pair of (arbitrary?) points in space?
Then the end tangent vectors from the original curve shall be extracted and parallel translated to their corresponding points in space?
Then a connecting curve shall be made between the "space points" with tangency direction stipulated by them previously transformed vectors?
Intrigued as I am, may I also ask what the use case for this is?
Perhaps a series of pictures (cartoon style) showing the work process would make it easier to understand?
GlouGlou
Postby GlouGlou » Wed Oct 28, 2020 9:52 pm
If I make 2 extrudes with the two vertexes, I get 2 lines. Then a sweep is easy to do, but need several operations.
Sweep_with_extrude.FCStd
(12.51 KiB) Downloaded 10 times
Pauvres_honteux
Postby Pauvres_honteux » Thu Oct 29, 2020 9:49 am
Okey, now I get what you want!
You want to sweep a "stick" / "rod" / "pin" / line / vector along a curve.
You also want that "stick" / "rod" / "pin" / line / vector to be parallel to something and keep that parallelity along the whole curve.
So the remaining question is, do you assume the green curve already exist or not? If it already exist, then the problem definition is almost solved. "Only" the "stick" / "rod" / "pin" / line / vector direction remains.
If the green curve shall be created at the same time, it'll be, at a minimum, intriguing.
Did that sum up your request?
GlouGlou
Postby GlouGlou » Thu Oct 29, 2020 11:51 am
Yes. And the green curve is the result. Can be "extracted" with joincurve for example.
Pauvres_honteux
Postby Pauvres_honteux » Thu Oct 29, 2020 1:54 pm
Just to put your request in perspective, there are 21 different ways of sweeping in Catia...
And almost every one of them variants are missing. But one step at the time! No need to panic, we'll get there, sooner or later.
Will you create this feature request, or shall I do it? (yes, I'm missing this "sweep a stick along a curve" -variant as well)
saso
Postby saso » Thu Oct 29, 2020 2:38 pm
Here are a few more examples I made about this in the past, basic idea is to have a few basic profile shapes (ex line, circle and rectangle) available directly in the tool https://forum.freecadweb.org/viewtopic. ... 57#p324957
Sabm01
Postby Sabm01 » Tue Nov 17, 2020 4:20 pm
Problem : Approximate creates 2 curves
I created a bspline in a sketch.
Then I use discretize to create a string of points
Then I use approximate to create a curve from the string of points.
I found 2 curves created. Why?
Test_approximate.FCStd
(13.74 KiB) Downloaded 3 times
Thanks for your time,
Michel
Michel Sabourin (Sabm01)
www.simturb.com
