Curves workbench
Chris_G
Re: Curves workbench
Postby Chris_G » Tue Nov 17, 2020 6:06 pm
Indeed.
I just pushed a fix.
Thanks.
GlouGlou
Postby GlouGlou » Tue Nov 17, 2020 9:15 pm
Info tools seems give the legth of the circle instead the arc length.
length.FCStd
(4.6 KiB) Downloaded 4 times
Chris_G
Postby Chris_G » Wed Nov 18, 2020 1:38 pm
GeomInfo was first intended to display Geometry info.
But since I already added a couple of topolgy info in the text (tolerance, 2d curves), it make sense to also display edge length.
It now display : Edge Length (+ Geometry curve length if different )
neildarlow
Postby neildarlow » Mon Nov 30, 2020 5:32 pm
Please may I highlight two tooltip quirks?
1)
I think the first word, displays, should be Display i.e. singular and first-letter as uppercase.
2)
I think this should read: Blend surface between two curveOnSurface objects i.e. noun instead of verb, lowercase Surface and two instead of to.
These are trivial changes but beneficial.
Regards,
Neil
Postby Kunda1 » Mon Nov 30, 2020 6:05 pm
Good catch. Submitted PR: https://github.com/tomate44/CurvesWB/pull/35
Chris_G
Postby Chris_G » Mon Nov 30, 2020 6:09 pm
Merged. Thanks.
Postby Kunda1 » Fri Dec 04, 2020 4:02 pm
Chris_G wrote: :bell:
@Chris_G in the UI there is a mixed curves command but it uses combined_curves.svg. Is it possible to rename one of them?
Edit: source: https://github.com/luzpaz/CurvesWB/blob ... rve.py#L16
There is a ./Curves/bezierCurve-2.py
This seems to be a dupe. Is that intentional? If it's a WIP, perhaps you can put it on a different branch so it doesn't pollute the main branch ?
It may be useful to put some separators in between the Curves toolbar commands. In order to group them. Or perhaps split the toolbar in to several smaller ones so that users can have the option to manipulate/reposition the toolbars to match their workflow?
Postby Kunda1 » Fri Dec 04, 2020 9:14 pm
In addition to the above. I've also created a PR while creating documentation on the wiki for Curves WB
https://github.com/tomate44/CurvesWB/pull/37
Postby Kunda1 » Sat Dec 05, 2020 2:02 am
GlouGlou wrote: :bell:
@GlouGlou would you be open to continue creating documentation in the wiki in regards to Curves Workbench ?
GlouGlou
Postby GlouGlou » Sat Dec 05, 2020 3:29 pm
I will try. ;) Could you make the templates for the empty pages, please.
