Curves workbench
Chris_G
Re: Curves workbench
Postby Chris_G » Mon Dec 28, 2020 2:23 pm
Before recent changes, Construction was a property of all Part geometry objects.
This is no longer true, so some python scripts might now raise an AttributeError :
<class 'AttributeError'>: 'Part. ...' object has no attribute 'Construction'
There is no general recipe to fix this, but if the line that triggers the AttributeError, look like :
if a_sketch.Geometry[i].Construction:
it can be replaced by :
try:
    construction = a_sketch.Geometry[i].Construction
except AttributeError:
    construction = a_sketch.getConstruction(i)
if construction:
GlouGlou
Postby GlouGlou » Sat Jan 09, 2021 8:57 am
I've got a bug this morning with interpolated curve. :?
interpolated_bug.FCStd
(9.45 KiB) Downloaded 15 times
hammax
Postby hammax » Sat Jan 09, 2021 10:40 am
... the bug must be in the derived points.
Using directly the corners of the cube, there is no problem.
No_interpolated_bug_2.FCStd
FC.18.4
(8.08 KiB) Downloaded 8 times
Chris_G
Postby Chris_G » Sat Jan 09, 2021 5:09 pm
Thanks. It should be fixed now.
Denisvp
Postby Denisvp » Thu Feb 04, 2021 9:54 am
Dear friends, please tell me how to connect a curve on a plane with two other curves. I want to build a surface using the tool "Sweep profiles on 2 rails". I want to draw several sections. I opened examples of files here, but I didn't understand how to do it.
Postby Kunda1 » Thu Feb 04, 2021 10:22 am
Is there one? I don't see the sweep profile on 2 rails in the Curves_Workbench.
Denisvp
Postby Denisvp » Thu Feb 04, 2021 10:49 am
I have two sections. initial and final, I need to insert another section in the middle where the plane passes. I do not know how to connect a curve, or rather I do not know how to get the point of intersection of curves with a plane.
middleSection.FCStd
(72.54 KiB) Downloaded 13 times
hammax
Postby hammax » Thu Feb 04, 2021 4:04 pm
... you even can position the curves endpoints by eye, in Sketcher "Section"
when increasing the 3D-tolerance in Gordon surface.
middleSection_2.FCStd
FC.18.1
(41.7 KiB) Downloaded 15 times
saso
Postby saso » Thu Feb 04, 2021 5:34 pm
I have two sections...
I am not sure if I understand what exactly you are trying to do, are you looking for something like this https://forum.freecadweb.org/viewtopic. ... 10#p387863 ?
GlouGlou
Postby GlouGlou » Thu Feb 04, 2021 6:05 pm
or using datum points. ;)
middleSection_3.FCStd
(23.33 KiB) Downloaded 14 times
