Help on drawing a worm gear with its involute gear
Dear all,
I beg your pardon, but I could not make this: Source: https://es.wikipedia.org/wiki/Archivo:Worm_Gear.gif
I've tried to adapt an involute gear to an existing thread from a fastener M8, but it seems impossible to match. Do you suggest that I should continue trying or is there a better approach?
Thank you!
This is my About:
OS: Ubuntu 16.04.2 LTS
Version: 0.16.6710 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: f8eca0f9311f07c125dd6742a607724c1fa0b77c
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Thank you!
This is my About:
Build type: None
- An example. Notice the curvature of the thoot.
- Selection_003.png (83.36 KiB) Viewed 6628 times
Re: Help on drawing a worm gear with its involute gear
Do you need an accurate model to 3D print or just an approximation?
I created a rough model by using the same tooth pattern for the the pinion and the gear (see the attached FreeCad file).
Hope that helps.
OS: Linux Mint 18 Sarah
Version: 0.17.11236 (Git)
Build type: None
Hash: 255b28138f6d512ce450e782a23c8cb739b0b306
OCC version: 7.1.0
Hope that helps.
Build type: None
OCC version: 7.1.0
Many thanks for your help.
My intention is 3d print this model. Perhaps it would be a bit easier if there is a way to move objects with the mouse, constrained to a working plane, but I could not find it.
Hello franceecad,
some weeks ago, there was a similar question on this forum.
Please have a look.
https://forum.freecadweb.org/viewtopic.php?f=3&t=13906
Please have a look.
Thank you, UR_...
Amazing! I did not find the topic
I will definitely investigate this example and the workbench. Thanks again!
Hi... I'm sorry but I'm not being able to get good results using this workbench... I read the documentation on Git hub but it is beyond my understanding.
Is there another doc to read or a more basic example to download?
Thank you in advance,
I had the same question, came across this thread and like to share a good solution i found on the way.
Here is a parametric globoid worm gear drive for OpenSCAD.
https://www.thingiverse.com/thing:2776688
It's nicely written. It explains the way to get geometry in the gif.
To import it in FreeCAD OpenSCAD Workbench paste the content of the 3 .scad files and adapt the parameters.
Pros: easy, fast, precise, good documented
Cons: won't be a native FreeCAD object.
Another drawback is that it will produce a tessellated shape like a mesh.
Importing an OpenScad file in FC will generate proper Features, not tessellated objects.
From the wiki:
From the wiki:
https://www.freecadweb.org/wiki/Import_OpenSCAD_codeFreeCAD will import the OpenSCAD-File and build up a tree with primitives and boolean operations
Hello
Here is a suitable approach often used in economic constructions:
a biconnic screw and a spur gear,
Can be improved by making a slightly inclined pinion parallel to the tangent to the screw
- vis biconique.FCStd
- (307.3 KiB) Downloaded 348 times
- vis biconique.PNG (80.26 KiB) Viewed 5391 times
