Getting rid of double/ overlapping polygons.
MartinM
Postby MartinM » Thu Jun 08, 2017 11:31 am
Hello all,
I've almost completed my design, however do to the amount of fusing two objects together, I have encountered so double vertices/ overlapping poly. I was wondering how I would go about removing them.
Thanks for the help ,everyone.
--MM
Re: Getting rid of double/ overlapping polygons.
Postby chrisb » Thu Jun 08, 2017 12:23 pm
If you are talking about solids (and not sketches) you may want to have a look at the refinement options:
- Open SCAD -> Refine Shape (parametric)
- Part -> Refine Shape (non parametric)
- Preferences->Part Design->automatically refine model ... (non parametric)
jmaustpc
Postby jmaustpc » Thu Jun 08, 2017 1:16 pm
please don't encourage people to use that option. Its dangerous. when opening models in different FreeCAD instances with that setting set differently will likely corrupt your model. Its better that people, in most cases, leave that at its default "do not automatically refine". If you want a "refine" then run one, usually as the last step, from OpenSCAD WB Refine ...or the non linked Part WB Refine, normally the OpenSCAD version is most convenient.
The issue is caused by the topological naming limitation.
Postby chrisb » Thu Jun 08, 2017 6:01 pm
Thanks for pointing it out. Next time I will be more explicit instead of hiding a warning in the "non parametric".
