Dear folks,
as we are restoring a house, I would like to model many aspects in CAD.
I have a SolidWorks background, so I would really like to use Sketcher and its parametric possibilities, rather than getting used to draft WB.
But I am completely at odds how to use a parametric sketch to generate the walls.
I my sketch uses complete wall infos (not only one line, but rather the outline of the wall already in the sketch), I am not able to tell the wall tool just to use one line of the sketch as the basis for the wall.
Can I generate for each wall a sketch with one line that is dependent on the more complex floor plan that I drew in Sketcher?
In Solidworks, this is quite simple - draw a new sketch and simply take a copy of a single line of an existing sketch.
Or what would be the way to go also in Freecad?
The architecture tutorials that I found were more focused on Darft WB which is more geared towards people used to Autocad I think.
I would love to get some hints.
Thank you so much!
Martin
P.S. I use Freecad 0.16, 6706
using sketcher WB and parametric sketch for house /walls
Re: using sketcher WB and parametric sketch for house /walls
If you have a sketch containing the whole floor plan, why not simply use Part Extrude or PartDesign Pad directly on it? You would need to use the Sketcher Trimming tool to make sure all the walls form an uninterrupted region/island with no crossing line otherwise you will not get a valid solid. Contrary to SolidWorks, you cannot cherry-pick elements from a sketch when creating a 3D feature.
The Arch Wall tool doesn't support this at this time, but it's been requested.
Not in the current 0.16.67xx stable version. You could in the 0.17 development version, but it would honestly be a hassle.
Dear NormandC
thank you so much for the answers!
I will try to form a solid in the way you describe.
Thank you so much!
A shame that this SolidWorks cherry picking of elements (be it sketch geometry or body lines) is not possible.
All the best
Martin
Thank you so much!
All the best
Martin
