How to use Z88 in FEM?
AhmedER
Post by AhmedER »
How to use Z88 as a solver instead of CalculiX?
After I made the following analysis, I tried FEM->Solver Job, but it isn't working.
OS: Linux Mint 18 Sarah
Version: 0.17.11084 (Git)
Build type: None
Hash: fa00b4f06a0c96de57a777d6532467dfd8e5d141
Python version: 2.7.12
OCC version: 7.1.0
Screenshot from 2017-07-08 01-07-01.png (152.29 KiB) Viewed 5115 times
Re: How to use Z88 in FEM?
Post by Kunda1 »
Please always post your FC version info (Help > About FreeCAD > Copy to clipboard)
AhmedER
Post by AhmedER »
Kunda1 wrote: Sat Jul 08, 2017 12:01 am Please always post your FC version info (Help > About FreeCAD > Copy to clipboard)
Sorry I forgot, I normally remember to add the info.
Build type: None
OCC version: 7.1.0
Post by NormandC »
AhmedER wrote: Sat Jul 08, 2017 1:19 am Version: 0.17.11084 (Git)
You are using an obsolete development version, 425 commits behind the one currently available (0.17.11509). A respectable number of them were in the FEM workbench.
How did you install it? If you installed through the freecad-daily PPA, it must mean that you froze the updates otherwise you would get updates every other day (sometimes daily) or once a week if your system is configured to check for updates weekly.
Also, activate the report view (View --> Panels menu): it will report errors, paste them here.
Post by bernd »
have you installed z88 binary? you can get it here https://github.com/LSCAD/Z88OS/tree/master/bin
Post by bernd »
would you post the file?
AhmedER
Post by AhmedER »
NormandC wrote: Sat Jul 08, 2017 2:04 am
The problem persisted after updating my FreeCAD.
Selecting "FEM->Solver Job Control" doesn't do anything, while choosing "FEM->run Solver Calculations" yield the following error
FemConstraintForce has Vertex reference shapes.
FemConstraintForce001 has Vertex reference shapes.
FemConstraintForce002 has Vertex reference shapes.
FEM preferences working dir is not set, the solver working directory is used.
Dir '' doesn't exist and cannot be created.
Dir '/tmp' will be used instead.
FemTools.setup_working_dir() --> self.working_dir = /tmp
True
SolidMaterial has Edge reference shapes.
FemInputWriterZ88 --> self.dir_name --> /tmp
FemInputWriterZ88 --> self.file_name --> /tmp/z88
3
Edge femmesh will be exported as 3D truss element nr 4
{'ISFLAG': '1', 'INTORD': '0', 'INTOS': '0', 'IHFLAG': '0'}
Multiple beamsections for Z88 not yet supported!
/tmp
/tmp
/tmp
Running the Python command 'FEM_SolverRun' failed:
File "/usr/lib/freecad-daily/Mod/Fem/PyGui/_CommandFemSolverRun.py", line 73, in Activated
self.fea.run() # test z88
File "/usr/lib/freecad-daily/Mod/Fem/FemToolsZ88.py", line 133, in run
self.z88_test_run()
File "/usr/lib/freecad-daily/Mod/Fem/FemToolsZ88.py", line 141, in z88_test_run
z88_testrun_binary = self.z88_binary + " -t -choly"
'FemToolsZ88' object has no attribute 'z88_binary'
Version: 0.17.11509 (Git)
Build type: None
Hash: fdedf8fb4d36043145e8498244177aae16c806a5
OCC version: 7.1.0
Post by bernd »
you need to set the path to your z88r binary file in preferences.
AhmedER
Post by AhmedER »
bernd wrote: Sat Jul 08, 2017 7:15 am you need to set the path to your z88r binary file in preferences.
I did that. The error is gone, but there is no results in sight.
This is the file
TrussZ88real.fcstd
(10.43 KiB) Downloaded 133 times
On an unrelated note. Have you tried coding for Calculix? Is there any forums/wiki/guides/... to help me learn how to do that? I am still trying to implement a general beam cross section, as opposing to the current limitation of rectangle and pipe. Do you recommend I try to develop it from the first place, or do you think the Z88OS will be better option?
Thank you for your time and guidance.
Ahmed
Post by bernd »
I get no results either. I need to have a closer look. This may take some time.
To try if your z88 runs in FreeCAD you could do the following.
- start FreeCAD
- go to start wb
- load 3D FEM example
- activate the analysis
- add an solver z88 object
- select the z88 solver
- click on the run analysis button
- a new result object should be created. You should get the same deformations as with Calculix
