Usage of Shape binder
kishore
Re: Usage of Shape binder
Post by kishore »
ickby wrote: Wed Sep 20, 2017 3:28 pm - First is using base objects. You achive that by selecting a object bevore creating the body, or changing the BaseFeature property of the body.
Is it possible to use another body as the base feature? This will be needed when I wish to modify the base body adding features to it and see them adopted in all other bodies that use it as base feature.
triplus
Post by triplus »
ickby wrote: Wed Sep 20, 2017 4:53 pm One idee: I did not try it, b ut it shoudl work to move a Draft clone into PDN boolean. So if one really wants to keep the original outside the body it would work :)
Draft Clone does it again! ;)
aflorz
Post by aflorz »
ickby wrote: Wed Sep 20, 2017 3:28 pm I had a quick look at the discussion. Indeed the ShapeBinder is not intended to become Part of the Model, if it gets merged, after e.g. Patting a face of it, it is a bug.
OS: Ubuntu 22.10 (ubuntu:GNOME/ubuntu)
Version: 0.21.31109 (Git) AppImage
Hash: c23ee7ad88433a0f00e84afae0a62fe738be0c09
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Seems that this bug still exists. The shapebinder became fused with the model in the attached file.
LEDbarforwebcam.FCStd
(857.6 KiB) Downloaded 19 times
Roy_043
Post by Roy_043 »
Just drag it out of the body (see PartDesign_ShapeBinder#Notes)
aflorz
Post by aflorz »
Roy_043 wrote: Thu Dec 08, 2022 11:16 pm Just drag it out of the body (see PartDesign_ShapeBinder#Notes)
Just tried that. The shape is still fused to the body.
The problem is the attachment of the sketch:
Get it fixed, and the first Pad will look like this:
Alas, as you have attached sketches to (generated) faces the model breaks due to the TNP. Instead of re-attaching things I rather recommend to fix it following the advice for creating stable models.
aflorz
Post by aflorz »
chrisb wrote: Fri Dec 09, 2022 5:01 am Alas, as you have attached sketches to (generated) faces the model breaks due to the TNP. Instead of re-attaching things I rather recommend to fix it following the advice for creating stable models.
Ok thanks, I'll try to follow those tips.
