Spreadsheet alias access
OS: Ubuntu 17.04
Version: 0.17.11528 (Git)
Build type: None
Hash: d31be3117de386b4f6cd3444e0b330db56dc6ba2
Python version: 2.7.13
OCC version: 7.1.0
In the attached minimal example, there's a spreadsheet, a simple sketch and an extrude thereof, modelling a wire.
The extrude takes for its length a cell value from the spreadsheet.
1) Alias access in spreadsheet
To store the wire length, set an alias of a spreadsheet cell, e.g. C3, to 'wire_length'. For convenience, the same name should be visible in front: the cell B3 should hold something like =C3.alias.
I can do it manually, but there will be about three dozen parameters, so I'm not looking forward to writing every alias string twice.
Ideas for an efficient workflow?
[edit: I'm fine with scripting... if there's something as described as a console one- or three-liner, that'd be awesome]
2) Alias access as property
In the Combo view, I can select the sketch and edit it's properties directly right there. In particular the one constraint it has, which corresponds to the wire thickness.
I can select the spreadsheet, and wire_length is tauntingly shown as a property, but it's not editable.
I think this would be a great quality of life improvement. (the wire_thickness will then go into the spreadsheet as well)
Build type: None
OCC version: 7.1.0
- spread.fcstd
- (6.87 KiB) Downloaded 64 times
Re: Spreadsheet alias access
Self do, self have
For the first question I came up with this. Seems sufficient for now.
edit: added as FCMacro
ss = App.ActiveDocument.Spreadsheet # spreadsheet name is hardcoded for now
for a in range(ord('B'), ord('Z')+1):
for i in range(1, 50):
cellalias = ss.getAlias(chr(a) + str(i))
if cellalias: # write alias string to left cell
ss.set(chr(a-1) + str(i), '\'' + cellalias);
- spreadsheet_alias_to_left.FCMacro.zip
- (473 Bytes) Downloaded 60 times
- microelly2
You can define your spreadsheet as a Spreadsheet::SheetPython and add the methods and properties you need
To start ...
To start ...
'''python objects for freecad'''
# -*- coding: utf-8 -*-
#-- microelly 2017 v 0.1
#-- GNU Lesser General Public License (LGPL)
##\cond
import FreeCAD
import FreeCADGui
App = FreeCAD
Gui = FreeCADGui
import Part
import numpy as np
class FeaturePython:
''' basic defs'''
def __init__(self, obj):
obj.Proxy = self
self.Object = obj
def attach(self, vobj):
self.Object = vobj.Object
def claimChildren(self):
return self.Object.Group
def __getstate__(self):
return None
def __setstate__(self, state):
return None
class ViewProvider:
''' basic defs '''
obj.Proxy = self
self.Object = obj
return None
return None
##\endcond
class MyTable(FeaturePython):
'''spreadsheet Object with Python'''
obj.Proxy = self
self.Type = self.__class__.__name__
ViewProvider(obj.ViewObject)
def onBeforeChange(proxy,obj,prop):
print "huhu"
obj = FreeCAD.ActiveDocument.addObject('Spreadsheet::SheetPython','name')
obj.addProperty("App::PropertyLink", "base", "Base",)
obj.addProperty("App::PropertyBool", "off", "Base",)
obj.addProperty("App::PropertyIntegerList", "relation", "Base",)
obj.addProperty("App::PropertyVector", "offset", "Base",)
MyTable(obj)
Nice.donjan wrote: ↑Tue Jul 11, 2017 6:42 pm Self do, self have
edit: added as FCMacroCode: Select all
ss = App.ActiveDocument.Spreadsheet # spreadsheet name is hardcoded for now for a in range(ord('B'), ord('Z')+1): for i in range(1, 50): cellalias = ss.getAlias(chr(a) + str(i)) if cellalias: # write alias string to left cell ss.set(chr(a-1) + str(i), '\'' + cellalias); App.ActiveDocument.recompute()
If you are willing to create a more usefull macro for GUI users you could add it to the following macro which allows copying parts of a spreadsheet with a gui (see the screencast fist):
https://forum.freecadweb.org/viewtopic. ... et#p164461
BR,
HoWil
Thanks, adding properties is a good idea.microelly2 wrote: ↑Tue Jul 11, 2017 7:09 pm You can define your spreadsheet as a Spreadsheet::SheetPython and add the methods and properties you need
To start ...
I can just take my snippet from above and say
ss.addProperty("App::PropertyBool", "off", "Base",)
Does anybody know how to monkey patch the spreadsheet object to enable editing from the combo view?
Well, one major issue is that I bluntly iterate over an arbitrary section of the table, which is sufficient for my personal needs.HoWil wrote: ↑Tue Jul 11, 2017 8:07 pm Nice.
BR,
HoWil
A less crazy and much more efficient method would be to read only what is in App.ActiveDocument.Spreadsheet.cells.Content, but I really don't feel like parsing XML and can't discover a Python-list version of those contents in the refs (to be fair I wasn't looking that hard).
So no, I'm not looking to spend substantial amounts of time on polishing this, which is why I was asking for a 1-3 liner originally
- microelly2
If you look into the fine structure of the Qt Widget for the spreadsheet you will find possibities to exchange data between spreadsheet and other widgets/propertiesdonjan wrote: ↑Tue Jul 11, 2017 8:27 pmThanks, adding properties is a good idea.microelly2 wrote: ↑Tue Jul 11, 2017 7:09 pm You can define your spreadsheet as a Spreadsheet::SheetPython and add the methods and properties you need
To start ...
I can just take my snippet from above and sayThe main issue is that the table cells are not editable, while properties added manually are.Code: Select all
I have done some work to get a good interaction between spreadsheet and model
It should be possible to transfer the ideas to your needs.
https://www.youtube.com/watch?v=f-6I7SRBDvs
https://youtu.be/jxyuS9JiYTQ
the scripts are in my nurbs workbench
https://github.com/microelly2/freecad-nurbs
I will extract a small example for your needs next days (it's to late this evening (for me) )
Looks neat. A clean simple extract would be nice, thanks!
For now, I don't use the property window editing: I'd have to add the property via console, then add =propertyname to a cell, then add 'propertyname to the left neighbour cell, for each property. Sure, part of that can be automated, but the goal is to have it be convenient.
How do you get those Qt window views? I'm on GTK+Compiz (no Unity) and can pick View -> Document window -> Undocked, which takes the first view out of the app, and subsequent views as in-app windows (Qt titlebar with min,max,close) as in your video, but I can't manage to get all of them inside. That's on yesterdays 0.17 daily.
edit: nevermind, Windows -> Tile
Schönen Tag noch.
Schönen Tag noch.
- microelly2
Here the idea how to access the cells of the spreadsheet by mouse events
class MeineTabelle:
def clicked(self,index):
print "Clicked",index
print ("dumpix", index.row(),index.column(),index.data())
def entered(self,index):
print "Entered"
def pressed(self,index):
print "Pressed"
def startssevents(self):
mw=FreeCADGui.getMainWindow()
mdiarea=mw.findChild(QtGui.QMdiArea)
App.activeDocument().SpreadsheetABC.ViewObject.startEditing(0)
subw=mdiarea.subWindowList()
for i in subw:
if i.widget().metaObject().className() == "SpreadsheetGui::SheetView":
sheet = i.widget()
table=sheet.findChild(QtGui.QTableView)
table.clicked.connect(self.clicked)
table.entered.connect(self.entered)
table.pressed.connect(self.pressed)
self.table=table
obj=App.activeDocument().addObject('Spreadsheet::Sheet','SpreadsheetABC')
obj.addProperty("App::PropertyString", "MeinParam", "Base",)
# in die zellen schreiben
obj.set('A9', '23')
obj.set("B4","45")
#zugriffe auswerten
mt=MeineTabelle()
mt.startssevents()
