[Solved] Unexpected Klein bottle during PDN loft
Sam
Postby Sam » Tue Aug 08, 2017 2:08 am
OS: Ubuntu 16.04.3 LTS
Version: 0.17.11740 (Git)/Daily-PPA
Build type: None
Hash: 6b05302c2e70f191a2a5787f55c5b549155b9824
Python version: 2.7.12
OCC version: 7.1.0
In the attached file there is a stack of sketches that I'd like to loft through. In fooling around it seems that pretty much any combination works as expected, except all of them in order from base to top. When they are all selected in order (base, 10, 15, 20, 30, 40, top) Freecad seems to try and make some kind of Klein bottle.
My guess is that one of the sketches is upside down, but I can't see or find it.
There is another issue apparent in this file. The loft dialog uses the internal names of the sketches, not their label. This might not be a bug, but it does look like a blatant absence of an expected feature.
loft experiment 13.fcstd
(16.35 KiB) Downloaded 38 times
NormandC
Re: Unexpected Klein bottle during PDN loft
Postby NormandC » Tue Aug 08, 2017 8:46 pm
Klein bottle
That's a new one to me, my mathematics background is pretty basic.
Just looking at the sketches in the 3D view, you can see that there's a vertex along each ellipse. I think this is required by OCC, like for seam edges on cylinders. Anyway, the vertices are not all aligned. Maybe that's what's causing the issue? I would try to rotate the sketches so that all the vertices are aligned on one side.
Have you considered creating a sweep instead? With a sweep path, you could create datum planes for each sketch on its normal, which would allow you to rotate the sketches easily using the Extra Placement properties.
Sam
Postby Sam » Wed Aug 09, 2017 5:15 am
I don't have time to explore this in detail right now, but I did as you suggested and it appears to have solved my problem.
Is this a bug? Or a feature?
Fooling around raised a couple of other questions, but I'll come back to those tomorrow.
Thanks for taking the time to look at this for me, my friend.
loft experiment 14.fcstd
(28.84 KiB) Downloaded 23 times
Postby chrisb » Wed Aug 09, 2017 10:22 am
If you loft from top to bottom it works with the file in the OP.
OS: Mac OS X
Branch: (detached from 6b05302)
Python version: 2.7.13
Qt version: 5.6.2
OCC version: 7.1.0
Sam
Postby Sam » Wed Aug 09, 2017 10:59 am
Ha! That's reassuring. Thanks for taking a look mate.
Edit: I just tried that. You're correct. For certain categories of "works".
Screenshot from 2017-08-10 00-09-35.png (119.43 KiB) Viewed 1168 times
Chris_G
Postby Chris_G » Wed Aug 09, 2017 3:20 pm
:lol:
Indeed, the resulting shape is not what we would be expecting.
I inspected the resulting shape.
It is a BSpline surface of high degree (14) with an anarchical pattern of the control points.
I discretized the initial sketches, in order to create a custom approximating BSpline surface on which I have more control parameters.
At first, I got the same kind of bad result :
But when using the smoothing algorithm and limiting the maxdegree to 11, I got something much better :
The result looks more natural, and the underlying BSpline surface also has better shape.
FreeCAD file attached below.
I looked at the source code.
The makeLoft function uses OCC BRepOffsetAPI_ThruSections that offers these control functions ( smoothing algorithm, setting the max degree, setting the parametrization type).
So it may be good to have them implemented in the loft tool ?
Loft-2.fcstd
(49.15 KiB) Downloaded 20 times
Sam
Postby Sam » Wed Aug 09, 2017 10:16 pm
Thanks for taking a look Chris_G
I've had a look around for the tools you used to do this, but came up empty.
Would you mind giving me a clue what to google for please?
I had a play with the surface WB a while ago, but also failed to get it to do anything useful. The curves WB is also somewhat of a mystery to me, but looks like it has a lot of relevant tools...
Edit: Forgot to add: What you were doing there looks very cool!
Edit again: Searching the forum I see your thread Flatten a face. I fear your grasp of things FreeCAD will be forever beyond me!
Still another edit: I just saw that the Curves workbench belongs to you. This explains a few things! :D :ugeek:
Chris_G
Postby Chris_G » Thu Aug 10, 2017 1:21 pm
I first thought you were only interested in the loft result of your FC file.
But if you are curious about Bezier and BSpline surfaces, I used the GeomInfo tool of my workbench.
This the highlighted icon in the screenshot below :
Sam
Postby Sam » Thu Aug 10, 2017 9:53 pm
Thanks.
Don't think you wasted your time, I am interested in getting that loft to work.
I'd also like to learn how to create and manipulate more complex curves and surfaces. Your post intrigued me. :geek: I have been given some good tips for learning generic background in this thread; there's little value in ignorance.
Sam
Postby Sam » Thu Aug 10, 2017 10:45 pm
As far as I'm concerned, I have been helped to achieve what I was after. Thanks for that.
My question now:
Is the issue seen in the OP expected behaviour? It seems unlikely.
If it isn't, should I raise an issue in the tracker?
