output is saved in pdf without calling freecad
diljot6791
Postby diljot6791 » Sun Mar 18, 2012 6:50 pm
hi everyone,
Can we do scripting in terminal and our output is saved in pdf (only output in drawing viewer or any 2d objects ) without opening the freecad software. can we call freecad in terminal ??
cheers,
diljot
helo10
Re: output is saved in pdf without calling freecad
Postby helo10 » Sun Mar 18, 2012 8:14 pm
hi diljot,
you can start FreeCAD without Gui
FreeCAD -c
but export to pdf is not possible, I think.
helo
NormandC
Postby NormandC » Mon Mar 19, 2012 4:27 am
There's a File --> Export to PDF menu, so it must be possible.
Site Admin
Postby wmayer » Mon Mar 19, 2012 10:29 am
For the export of PDF we use some built-in functionality of our GUI toolkit Qt. This class is part of the QtGui module so it means that exporting to a PDF _without_ showing the FreeCAD GUI is _not_ possible.
hardeeprai
Postby hardeeprai » Thu Mar 29, 2012 6:37 pm
Sad :-(
I admire Linux becasue of it's ability to make things non-interative, and automated. Batch processing is nice thing. OpenOffice may be used as headless, producing pdf from a OpenOffice file is possible. Scene may created in text file and script may be execited to render it and to produce a picture using renderer like Povray.
In that line, I wish to see and use FreeCAD, to produce finished drawing, after reading data, without launch of GUI.
Please suggest, if there is any way. If not, is there demand, other also thing that this feature may be useful. If yes, we may develop it.
H.S.Rai
H.S.Rai
Site Admin
Postby wmayer » Fri Mar 30, 2012 4:44 pm
I have played a bit and found a hopefully suitable solution:
We can add a new command line parameter "--output" followed by a file name which tells FreeCAD to save the loaded file.
Therefore we have to load the GUI to have the Pdf export function available and if needed FreeCAD can be hidden (with a second command line parameter "--hidden") so that you won't even realize that it has started. After the export has finished we simply quit FreeCAD again.
Site Admin
Postby wmayer » Sat Mar 31, 2012 12:11 pm
So, I have implemented the above idea. Once you have the latest version from the sources you can do it like this
E.g.:
freecad --hidden --output=output.pdf inputfile.fcstd
