[solved] Export Dependency Graph?
wandererfan
Postby wandererfan » Tue Aug 22, 2017 4:36 pm
Is there a way to export the Dependency Graph in a form that is suitable for "marking up"? (highlighting sections, adding comments, etc).
I use screen grabs now, but they can be quite blurry on big graphs.
Thanks,
wf
Reason: added "[Solved]" to the title
Site Admin
Re: Export Dependency Graph?
Postby wmayer » Tue Aug 22, 2017 5:18 pm
From Python you can export the dependency graph in text form with:
App.ActiveDocument.exportGraphviz()
From C++ you can do it using the method exportGraphviz of App::Document. As argument it expects an output stream which can be a string stream or a file stream for example.
Willem
Postby Willem » Tue Aug 22, 2017 5:53 pm
when you do <CTR>S or select save on the pull down menu the dependency graph is saved as a PNG file of a good quality.
With GIMP I make remarks on it
wandererfan
Postby wandererfan » Wed Aug 23, 2017 1:34 am
File>Save is great!
Not sure what to do with the text version yet, but good to know about.
'digraph "" {\n
graph [\ncompound=true];\n
subgraph clusterPart {\ngraph [\n
bgcolor="#53906750", label="Part&#92;n(thing through hoop)", style="rounded,filled"];\n
subgraph clusterBody {\n
graph [\n
bgcolor="#124f9a50", label="Body&#92;n(hoop)", style="rounded,filled"];\n
subgraph clusterOrigin001 {\n
graph [\n
bgcolor=none, label=Origin001];\n
Thank you,
wf
wandererfan
Postby wandererfan » Wed Aug 23, 2017 1:39 am
Std_DependencyGraph :oops:
Just choose File → Save As to save the graph as a picture (PNG/BMP/GIF/JPG), a vector graphic (SVG) or as a pdf-file (PDF).
bejant
Re: [solved] Export Dependency Graph?
Postby bejant » Wed Aug 23, 2017 5:11 am
Hi wf, I saved a piece of history for you:
https://forum.freecadweb.org/viewtopic. ... 56#p187756
P.S.: thank you for all the work you're doing on Tech Draw!
