[v0.17] Dependency graph: Graphviz failed to create an image file
industromatic
Postby industromatic » Sun Sep 10, 2017 6:33 pm
I'm not a newbie, I have gotten a small amount of successful experience with freecad. I seem to aim for a top down parametric way to use freecad that is different than most. I have a doc with rather short chains of anything and yet it already is failing to make a dependency graph.
I get the error: Graphviz failed to create an image file.
My goal in creating this doc was to have independent modular reusable chunks of 3D parts to combine to make things, so it couldn't have been that deep a dependency graph.
cs-enc-spread-driven-9.fcstd
(280.84 KiB) Downloaded 21 times
A simpler file does create a dependency graph with same version of freecad.
  • OS: Debian GNU/Linux testing (buster)
    Version: 0.17.11967 (Git)
    Hash: d0c5865f323aa9555662912f2ff96188f29096a6
    Python version: 2.7.13
    OCC version: 7.1.0
peterl94
Re: [v0.17] Dependency graph: Graphviz failed to create an image file
Postby peterl94 » Sun Sep 10, 2017 7:33 pm
Interesting, with the following version on macOS, I can create a graph of that file with no problem.
OS: Mac OS X
Version: 0.17.12058 (Git)
Hash: 832e18689b1be199056f3fd150c0fa8a7d2f0b3d
Qt version: 5.6.2
OCC version: 7.1.0
[graphviz: 2.36]
However, I get the same error as you on Windows (same freecad version 0.17.12058, but using graphviz 2.38).
Site Admin
Postby wmayer » Mon Sep 11, 2017 7:09 am
On Windows I have graphviz 2.38 and when trying to create the picture I get a crash report that dot.exe stopped working. dot.exe is the utility of graphviz that creates the image file.
When exporting the graph to an external file with
graph=App.ActiveDocument.exportGraphviz()
f=open("graph.viz","w")
f.write(graph)
f.close()
and then using dot.exe with:
it prints a couple of warnings
Warning: node '19', graph '' size too small for label
Warning: node '8', graph '' size too small for label
Warning: node '16', graph '' size too small for label
Warning: node '1', graph '' size too small for label
Warning: node '18', graph '' size too small for label
Warning: node '27', graph '' size too small for label
Warning: node '25', graph '' size too small for label
Warning: node '21', graph '' size too small for label
Warning: node '30', graph '' size too small for label
Warning: node '33', graph '' size too small for label
Warning: node '2', graph '' size too small for label
Warning: node '22', graph '' size too small for label
Warning: node '23', graph '' size too small for label
Warning: node '37', graph '' size too small for label
Warning: node '44', graph '' size too small for label
Warning: node '48', graph '' size too small for label
Warning: node '3', graph '' size too small for label
Warning: node '20', graph '' size too small for label
Warning: node '26', graph '' size too small for label
Warning: node '51', graph '' size too small for label
and then crashes.
ickby
Postby ickby » Mon Sep 11, 2017 7:28 am
I tried to disable the new depemndency-graph stuff like grouping, but it still fails:
BaseApp - Preferences - DependencyGraph: GeoFeatureSubgraphs = False
BaseApp - Preferences - DependencyGraph: Unflatten = False
So it seems there is something else going on.
industromatic
Postby industromatic » Wed Sep 13, 2017 8:18 pm
I don't need this freecad doc for anything, but it could be a repeatable result debugging opportunity. Should I file it as a bug?
Site Admin
Postby wmayer » Wed Sep 13, 2017 8:24 pm
Looks more like a graphviz bug because the dot utility crashes, not FreeCAD.
peterl94
Postby peterl94 » Wed Sep 13, 2017 8:29 pm
It works with version 2.36 on both macOS and Windows....maybe it is a regression on their part. I wonder if there is a way to work around it.
Site Admin
Postby wmayer » Wed Sep 13, 2017 8:54 pm
The file which makes dot to crash is:
digraph "" {
graph [
compound=true];
subgraph clusterPart {
graph [
bgcolor="#a3609650", label="Part\n(cs-enc-master)", style="rounded,filled"];
subgraph clusterBody {
graph [
bgcolor="#efe53e50", label="Body\n(cs-enc-master-body)", style="rounded,filled"];
subgraph clusterOrigin001 {
graph [
bgcolor=none, label=Origin001];
19[fixedsize=true, height=0, style=invis, width=0];
55[label=XY_Plane001, shape=Mrecord, style=filled];
60[label=XZ_Plane001, shape=Mrecord, style=filled];
65[label=X_Axis001, shape=Mrecord, style=filled];
70[label=YZ_Plane001, shape=Mrecord, style=filled];
75[label=Y_Axis001, shape=Mrecord, style=filled];
80[label=Z_Axis001, shape=Mrecord, style=filled];
subgraph clusterDatumLine {
graph [
bgcolor="#e0e0e0", label=DatumLine, style="rounded,filled"];
8[fixedsize=true, height=0, style=invis, width=0];
9[fontsize="8pt", label="superPlacement.Base.y", shape=box, style=dashed];
10[fontsize="8pt", label="superPlacement.Base.x", shape=box, style=dashed];
subgraph clusterDatumPlane001 {
graph [
bgcolor="#e0e0e0", label="DatumPlane001\n(cs-enc-back-rear-plane)", style="rounded,filled"];
16[fixedsize=true, height=0, style=invis, width=0];
17[fontsize="8pt", label="Placement.Base.z", shape=box, style=dashed];
1[fixedsize=true, height=0, style=invis, width=0];
15[label="DatumPlane\n(cs-enc-back-mating-plane)", shape=Mrecord, style=filled];
8 -> 80[ltail=clusterDatumLine];
subgraph clusterOrigin {
graph [
bgcolor=none, label=Origin];
18[fixedsize=true, height=0, style=invis, width=0];
54[label=XY_Plane, shape=Mrecord, style=filled];
59[label=XZ_Plane, shape=Mrecord, style=filled];
64[label=X_Axis, shape=Mrecord, style=filled];
69[label=YZ_Plane, shape=Mrecord, style=filled];
74[label=Y_Axis, shape=Mrecord, style=filled];
79[label=Z_Axis, shape=Mrecord, style=filled];
subgraph clusterSketch {
graph [
bgcolor="#e0e0e0", label="Sketch\n(cs-enc-master-xy)", style="rounded,filled"];
27[fixedsize=true, height=0, style=invis, width=0];
28[fontsize="8pt", label="Constraints.EncHeight", shape=box, style=dashed];
29[fontsize="8pt", label="Constraints.EncWidth", shape=box, style=dashed];
25[fixedsize=true, height=0, style=invis, width=0];
15 -> 27[color=red, lhead=clusterSketch];
subgraph clusterPart001 {
graph [
bgcolor="#fa9ea250", label="Part001\n(cs-enc-back)", style="rounded,filled"];
subgraph clusterBody001 {
graph [
bgcolor="#98d70b50", label="Body001\n(cs-enc-back-sweep)", style="rounded,filled"];
subgraph clusterOrigin003 {
graph [
bgcolor=none, label=Origin003];
21[fixedsize=true, height=0, style=invis, width=0];
57[label=XY_Plane003, shape=Mrecord, style=filled];
62[label=XZ_Plane003, shape=Mrecord, style=filled];
67[label=X_Axis003, shape=Mrecord, style=filled];
72[label=YZ_Plane003, shape=Mrecord, style=filled];
77[label=Y_Axis003, shape=Mrecord, style=filled];
82[label=Z_Axis003, shape=Mrecord, style=filled];
subgraph clusterSketch001 {
graph [
bgcolor="#e0e0e0", label="Sketch001\n(cs-enc-master-sweep-profile)", style="rounded,filled"];
30[fixedsize=true, height=0, style=invis, width=0];
31[fontsize="8pt", label="Constraints.EncCornerRadiusMin.1", shape=box, style=dashed];
subgraph clusterSketch002 {
graph [
bgcolor="#e0e0e0", label="Sketch002\n(cs-enc-sweep-outline)", style="rounded,filled"];
33[fixedsize=true, height=0, style=invis, width=0];
34[fontsize="8pt", label="Constraints.EncCornerRadius", shape=box, style=dashed];
35[fontsize="8pt", label="Constraints.EncWidth", shape=box, style=dashed];
36[fontsize="8pt", label="Constraints.EncHeight", shape=box, style=dashed];
0[label=AdditivePipe, shape=Mrecord, style=filled];
2[fixedsize=true, height=0, style=invis, width=0];
0 -> 33[lhead=clusterSketch002];
0 -> 30[lhead=clusterSketch001];
subgraph clusterBody002 {
graph [
bgcolor="#d3066650", label="Body002\n(cs-enc-back-floor-n-bosses)", style="rounded,filled"];
subgraph clusterOrigin004 {
graph [
bgcolor=none, label=Origin004];
22[fixedsize=true, height=0, style=invis, width=0];
58[label=XY_Plane004, shape=Mrecord, style=filled];
63[label=XZ_Plane004, shape=Mrecord, style=filled];
68[label=X_Axis004, shape=Mrecord, style=filled];
73[label=YZ_Plane004, shape=Mrecord, style=filled];
78[label=Y_Axis004, shape=Mrecord, style=filled];
83[label=Z_Axis004, shape=Mrecord, style=filled];
subgraph clusterPad {
graph [
bgcolor="#e0e0e0", label=Pad, style="rounded,filled"];
23[fixedsize=true, height=0, style=invis, width=0];
24[fontsize="8pt", label=Length, shape=box, style=dashed];
subgraph clusterSketch003 {
graph [
bgcolor="#e0e0e0", label="Sketch003\n(cs-enc-floor-outline)", style="rounded,filled"];
37[fixedsize=true, height=0, style=invis, width=0];
38[fontsize="8pt", label="Constraints.EncCornerRadiusMin.5", shape=box, style=dashed];
39[fontsize="8pt", label="Constraints.EncWidth+1", shape=box, style=dashed];
40[fontsize="8pt", label="Constraints.EncCornerRadiusMin.5-", shape=box, style=dashed];
41[fontsize="8pt", label="Constraints.EncHeight+1", shape=box, style=dashed];
42[fontsize="8pt", label="Constraints.EncScrewHeadRad", shape=box, style=dashed];
subgraph clusterSketch004 {
graph [
bgcolor="#e0e0e0", label="Sketch004\n(cs-enc-subtract-sweep-outline)", style="rounded,filled"];
44[fixedsize=true, height=0, style=invis, width=0];
45[fontsize="8pt", label="Constraints.EncCornerRadius", shape=box, style=dashed];
46[fontsize="8pt", label="Constraints.EncWidth", shape=box, style=dashed];
47[fontsize="8pt", label="Constraints.EncHeight", shape=box, style=dashed];
subgraph clusterSketch005 {
graph [
bgcolor="#e0e0e0", label="Sketch005\n(cs-enc-back-subtract-sweep-profile)", style="rounded,filled"];
48[fixedsize=true, height=0, style=invis, width=0];
49[fontsize="8pt", label="Constraints.Constraint17", shape=box, style=dashed];
50[fontsize="8pt", label="Constraints[20]", shape=box, style=dashed];
4[fontsize="8pt", label="Placement.Base.z", shape=box, style=dashed];
6[label=Cone, shape=Mrecord, style=filled];
7[label=Cylinder, shape=Mrecord, style=filled];
52[label="SubtractivePipe\n(cs-enc-back-subtract-sweep-1)", shape=Mrecord, style=filled];
53[label="SubtractivePipe001\n(cs-enc-back-subtract-sweep-2)", shape=Mrecord, style=filled];
7 -> 23[lhead=clusterPad];
23 -> 37[lhead=clusterSketch003, ltail=clusterPad];
23 -> 6[ltail=clusterPad];
37 -> 58[ltail=clusterSketch003];
52 -> 44[lhead=clusterSketch004];
52 -> 48[lhead=clusterSketch005];
52 -> 7;
53 -> 44[lhead=clusterSketch004];
53 -> 48[lhead=clusterSketch005];
53 -> 52;
subgraph clusterOrigin002 {
graph [
bgcolor=none, label=Origin002];
20[fixedsize=true, height=0, style=invis, width=0];
56[label=XY_Plane002, shape=Mrecord, style=filled];
61[label=XZ_Plane002, shape=Mrecord, style=filled];
66[label=X_Axis002, shape=Mrecord, style=filled];
71[label=YZ_Plane002, shape=Mrecord, style=filled];
76[label=Y_Axis002, shape=Mrecord, style=filled];
81[label=Z_Axis002, shape=Mrecord, style=filled];
26[fixedsize=true, height=0, style=invis, width=0];
subgraph clusterSpreadsheet {
graph [
bgcolor="#e0e0e0", label="Spreadsheet\n(dimensions)", style="rounded,filled"];
5[fontsize="8pt", label=EncBackDepth, shape=box, style=dashed];
11[fontsize="8pt", label=EncBossSideDist, shape=box, style=dashed];
12[fontsize="8pt", label=EncHeight, shape=box, style=dashed];
13[fontsize="8pt", label=EncWallThick, shape=box, style=dashed];
14[fontsize="8pt", label=EncWidth, shape=box, style=dashed];
32[fontsize="8pt", label=EncCornerRadius, shape=box, style=dashed];
43[fontsize="8pt", label=EncScrewHeadRad, shape=box, style=dashed];
51[fixedsize=true, height=0, style=invis, width=0];
4 -> 5[arrowsize=0.5, style=dashed];
6 -> 15[color=red];
7 -> 8[color=red, lhead=clusterDatumLine];
9 -> 11[arrowsize=0.5, style=dashed];
9 -> 12[arrowsize=0.5, style=dashed];
9 -> 13[arrowsize=0.5, style=dashed];
10 -> 11[arrowsize=0.5, style=dashed];
10 -> 13[arrowsize=0.5, style=dashed];
10 -> 14[arrowsize=0.5, style=dashed];
17 -> 5[arrowsize=0.5, style=dashed];
24 -> 13[arrowsize=0.5, style=dashed];
28 -> 12[arrowsize=0.5, style=dashed];
29 -> 14[arrowsize=0.5, style=dashed];
31 -> 32[arrowsize=0.5, style=dashed];
33 -> 15[color=red, ltail=clusterSketch002];
34 -> 32[arrowsize=0.5, style=dashed];
35 -> 14[arrowsize=0.5, style=dashed];
36 -> 12[arrowsize=0.5, style=dashed];
38 -> 32[arrowsize=0.5, style=dashed];
39 -> 32[arrowsize=0.5, style=dashed];
39 -> 14[arrowsize=0.5, style=dashed];
40 -> 32[arrowsize=0.5, style=dashed];
41 -> 32[arrowsize=0.5, style=dashed];
41 -> 12[arrowsize=0.5, style=dashed];
42 -> 43[arrowsize=0.5, style=dashed];
44 -> 15[color=red, ltail=clusterSketch004];
45 -> 32[arrowsize=0.5, style=dashed];
46 -> 14[arrowsize=0.5, style=dashed];
47 -> 12[arrowsize=0.5, style=dashed];
49 -> 32[arrowsize=0.5, style=dashed];
50 -> 32[arrowsize=0.5, style=dashed];
When removing this block at the end
then dot doesn't crash any more.
Site Admin
Postby wmayer » Wed Sep 13, 2017 9:04 pm
Playing a bit further only these two lines are responsible to make dot fail:
But as there is nothing wrong in the syntax this must be clearly a graphviz.
GeneFC
Postby GeneFC » Wed Sep 13, 2017 11:45 pm
I had regular crashes of dot.exe for a long time. I reverted from version 2.38 back to 2.36, and the crashes stopped.
I just tried the supplied file from the OP. It crashed with 2.38 and worked fine with 2.36. Some sort of regression or a new "feature" in GraphViz.
OS: Windows 7
Version: 0.17.11939 (Git)
Hash: 6e7952ec672895900eec0c2a25807b25befba818
Python version: 2.7.8
OCC version: 7.1.0
(Yes, a bit out of date, but probably not important for this purpose.)
Gene
