Sam wrote: ↑Wed Sep 13, 2017 12:09 am
And I see it's been updated recently. Is this a real thing I can use somehow?
@agryson updated the FreeCAD icons not too long ago, but I think it is still unused. Instead, you can place a Point, Constrain it onto a line segment with the Point On Edge Constraint:
then use the Symmetry Constraint to center the Point between the endpoints of the line segment.
And while I'm here, what's the easiest way to link one of those images from Artwork?
I don't know if this is the easiest way, but it's how I do it:
From the Artwork page, right-click on the icon you'd like to link to.
From the pop-up menu select "Copy Image Location".
When typing my reply, I click the Image button (above the text entry window).
The
tags appear and my cursor is centered between them.
Then I do a Ctrl + V to paste the image location.
In the text input window it looks like this:
[img]https://www.freecadweb.org/wiki/images/0/0b/Constraint_PointOnMidPoint.svg[/img]
And after posting, it looks like this:
Isn't that what you did?
