Sure. You meshed a fuse. The fuse does not know about the inner face, thus theres is not FEM-node on the inner face, thus the inp file writer does not know which element is which solid. See attached screen. That is why you have to use the CompSolids. With compsolids the mesher knows about the inner face and can place nodes on that face.lambda wrote: ↑Mon Sep 25, 2017 11:11 am Attached you find a minimal example of the fused parts causing an error when writing the .inp file, that I mentioned in my initial post. I have included the FemMesh as it is quite small and maybe there is something wrong with my mesher setup. All you need to do to reproduce is to load the file, activate the analysis, select the solver object, start the solver and click "Write .inp file" button. After a few seconds there will be a message "Error in get_femelement_sets -- > femelements_count_ok() failed!" in the console.
What you could do is make a compound of the two solids. Than the inp writer will work but than the two solids are not connected in the mesh because every solid will have its own nodes on the inner face. Thus again CompSolids. With a compsolid the solids share the inner face and thus they share the nodes in the FEM mesh. Thus the solids will be connected and there will be nodes on the inner face.
Bernd
