Path process/bugs
cahlfors
Path process/bugs
Post by cahlfors »
Hello forum!
I am trying to mill the following object:
What's the intended strategy to do this?
  • 1 Face mill the upper step and then
  • 2 face mill the lower step, or
  • 3 pocket mill the lower step, or
  • 4 something else?
No matter how I try this, there will be artifacts which I would like to report. But first, I want to be sure to use the intended procedure, so can you pls help me with this?
Thanks, /Chris
OS: Linux Mint 18 Sarah
Version: 0.17.12222 (Git)
Build type: None
Hash: 9d7240f695edeb236147d0800ae8dbd9643327e6
Python version: 2.7.12
OCC version: 7.1.0
Locale: Swedish/Sweden (sv_SE)
electrical engineer
Ubuntu or Mint
Mendel 3d-printer/OctoPrint
LinuxCNC
Optimum BF20L mill
Re: Path process/bugs
Could you please attach your file so we can see what you have done?
cahlfors
Post by cahlfors »
Here it is
Z.fcstd
(34.75 KiB) Downloaded 30 times
electrical engineer
Ubuntu or Mint
LinuxCNC
Optimum BF20L mill
It seems that you did not select the faces which you want to mill. It works perfect here:
Bildschirmfoto 2017-10-01 um 00.56.55.png (23.25 KiB) Viewed 1224 times
OS: Mac OS X
Branch: (detached from 9d7240f)
Python version: 2.7.14
Qt version: 5.6.2
OCC version: 7.1.0
Z_cb.FCStd
(25.27 KiB) Downloaded 22 times
cahlfors
Post by cahlfors »
Thanks for reaching out! :)
I was planning to use the facing operation (50mm face mill) and there you can select the entire part. Pockets have the disadvantage of creating artifacts in the corners. Ideally, the part should not require cutting, filing etc. postprocessing.
electrical engineer
Ubuntu or Mint
LinuxCNC
Optimum BF20L mill
You are not talking about artefacts in the path object but about the left overs not getting milled due to radius compensation? On the top surface this is of course no problem, on the lower surface it could be handled with a dogbone dressup. However, I could not get them working.
@mlampert: Is there currently a problem with the dressups? I havent heard something for a long time about them so they might have been forgotten with all the nice reworking you did.
cahlfors
Post by cahlfors »
chrisb wrote: Mon Oct 02, 2017 9:27 pm You are not talking about artefacts in the path object but about the left overs not getting milled due to radius compensation?
I mean the leftovers in the corners that are not getting milled because of the radius of the tool, which is just touching the outer boundary instead of milling clear, which makes sense when milling a fully enclosed pocket. Not sure if that is the same as radius compensation. I never understood the concept and have just learned to ignore it.
Now, I am not an advanced user and my lack of experience is why I am asking for advice first.
I have seen Sliptonic's video tutorial on dogbone dressups and I see what you mean. That should work, but means manual "intervention". Creating a helper object as I have done is another manual intervention to solve the problem.
Z.fcstd
(34.53 KiB) Downloaded 20 times
electrical engineer
Ubuntu or Mint
LinuxCNC
Optimum BF20L mill
