TechDraw templates scale
Today the Drawing workbench disappeared, I know that this is a profile issue but I thought lets give TechDraw a try.
I noticed that when I create a new page the locations of the editable text is not in the correct place , I also loaded the ANSI templates that Mario52 created and they have the same issue (see images below). If you use the Drawing Dimension tool it shown the points and lines to select out of the viewing window like they are scaled way too big, once you select the points and close the dialog box the dimension is placed in the correct position.
I looked in the TechDraw preferences but I dont see any obvious settings to adjust, I also opened the svg files with Inkscape and the XY locations of the editable text seem correct.
Am I missing a setting somewhere.
OS: Linux Mint 18 Sarah
Version: 0.17.12433 (Git)
Build type: None
Hash: 489c8c9aefbd38cd51751de9b25113b9d2032e80
Python version: 2.7.12
OCC version: 7.1.0
Build type: None
OCC version: 7.1.0
Re: TechDraw templates scale
I deleted the user.cfg and system.cfg files and the drawing templates are now showing up correctly. I am still curious about what makes the svg templates behave strangely.
PS:
I placed the ANSI templates in the user ./home/polifemos/.FreeCAD/Mod/Drawing/Templates directory and changed the TechDraw default path, is that the correct way to add templates?
Thanks
Build type: None
OCC version: 7.1.0
PS:
Thanks
Build type: None
OCC version: 7.1.0
I forgot to mention the issue only happens when using the templates from the Drawing module or the templates downloaded from the WIKI, the templates from the TechDraw module work correctly.
I guess I'll go back and read some more
I'm embarrased
Right on the TechDraw WIKI
TechDraw drawings and Python API are not interchangeable with the Drawing module. It is possible to convert Drawing Pages to TechDraw Pages using Python (moveViews.py). It is possible to have both TechDraw and Drawing Pages in the same FreeCAD document.
hi salp
yes is not well positioned but the position in the template is good (Misc_templates_Full)
(English page)
ps: the French page is +/- good !? (can deepen the creation of the page)
mario
(English page)
mario
- wandererfan
chin up, happens to me all the time.
TechDraw can not handle editable field definitions that are affected by an SVG transform clause (like this one):
<g transform="translate(87,-65)">
<g
id="titleblock-text-editable"
style="font-size:5px;text-anchor:start;fill:#000000;font-family:osifont"
xml:space="preserve">
<text freecad:editable="AUTHOR_NAME" x="108" y="171"><tspan>AUTHOR NAME</tspan></text>
<text freecad:editable="DRAWING_TITLE" x="168" y="171"><tspan>DRAWING TITLE</tspan></text>
<text freecad:editable="SI-1" x="108" y="182"><tspan></tspan></text>
<text freecad:editable="FreeCAD_DRAWING" x="108" y="189"><tspan>FreeCAD DRAWING</tspan></text>
<text freecad:editable="SI-3" x="108" y="196"><tspan></tspan></text>
<text freecad:editable="FC-SI" x="233" y="171"><tspan>A4</tspan></text>
<text freecad:editable="FC-SH" x="251" y="171"><tspan>X / Y</tspan></text>
<text freecad:editable="FC-SC" x="271" y="171"><tspan>SCALE</tspan></text>
<text freecad:editable="PN" x="231" y="181"><tspan>PN</tspan></text>
<text freecad:editable="DN" x="231" y="189"><tspan>DN</tspan></text>
<text freecad:editable="FC-DATE" x="231" y="197"><tspan>DD/MM/YYYY</tspan></text>
<text freecad:editable="FC-REV" x="269" y="197"><tspan>REV A</tspan></text>
</g>
Lines, literal text, graphics etc within the template definition can use transform.
wf
It is annoying that in inkcape, when for example you move a text, instead of changing the X and Y values of the <text> element,it adds it to a new group with a transform.. I wish they had an option to prevent that, or a way to remove unnecessary groups like that
Hey guys,
I have the same problem, but I am not sure if I understood the solution in this thread.
What do I have to do?
This is my system:
This is my problem:
And this is a part of the XML-Code:
I used inkscape to edit the svg and had a close look to the XML-Editor.
After that I tried to "adjust" the green dots on editing the SVG as XML in text-editor.
Can somebody find my mistake?
Regards
Michael
This is my system:
OS: Windows 7
Version: 0.17.10802 (Git)
Hash: 10ce910c03347a90712327a7cc7be2bcdee13afc
Python version: 2.7.8
OCC version: 7.0.0
<g
style="font-size:5px;font-family:osifont;text-anchor:start;fill:#000000"
transform="matrix(2.8346456,0,0,2.8346456,-81.520816,-241.50846)">
<text
freecad:editable="Dokumententitel"
x="220.72714"
y="244.2408"
id="text52"><tspan
x="220.72714"
y="244.2408"
id="tspan50">Dokumententitel</tspan></text>
<text
freecad:editable="Untertitel1"
x="221.14009"
y="247.44516"
id="text56"
style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:2.11666679px;font-family:osifont;-inkscape-font-specification:'osifont, Normal';font-variant-ligatures:normal;font-variant-caps:normal;font-variant-numeric:normal;font-feature-settings:normal;text-align:start;writing-mode:lr-tb;text-anchor:start"><tspan
id="tspan54" x="221.14009" y="247.44516"
style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:2.11666679px;font-family:osifont;-inkscape-font-specification:'osifont, Normal';font-variant-ligatures:normal;font-variant-caps:normal;font-variant-numeric:normal;font-feature-settings:normal;text-align:start;writing-mode:lr-tb;text-anchor:start">Untertitel 1</tspan></text>
Regards
Michael
Please update your version to be prepared for an answer of a TechDraw-insider. You are 2000 commits behind and I bet a lot of them concern TechDraw.
... did
... but as expected, it's the same.
Michael
OS: Windows 7
Version: 0.17.13086 (Git)
Hash: f64760b8a3dabf9d218418f6a3980d900b39d703
OCC version: 7.1.0
Michael
