Returns a strange form
Connect chamfered structures to 45 °
Re: Connect chamfered structures to 45 °
P.S. But then again it does look like a command like Part Connect is (at least up to a point) intended for completing such tasks:
I'm on the ass (and on my seat), it's so simple with this tool
Wow, never thought these Part pipe tools could handle such situations... Trying now too, indeed the result is very impressive. Tolerance might need to be raised a bit (setting it to 1mm gives very good results for me)
Great result Yorik!. Unfortunately I can not get the same thing. I tried to change all available options (Refine and Tolerance), but the result is not valid as yours. Tested in Linux and Windows, FC0.16 and FC0.17. Where am I wrong?
Refine->False, Tolerance 0,5 Refine->True, Tolerance 0,5 Tolerance 1 Can you publish your file?
EDIT I can get a look similar to yours if I do Cutout and a Clone of the "tool part".
Hi Renato.
Sometimes it will just work but when something like this happens:
Try to adjust the X,Y (or Z) Placement property of one of the beams by a few nm. Until the result on the screen looks OK.
Thanks. Something has to be improved. For now I have this. Not bad. Renatothschrader wrote: ↑Wed Nov 01, 2017 9:39 pm Hello renato,
you can use the "cut-plane" tool from arch-wb to trim the beams.
First: select beam to trim in model tree
Second: select cutting plane on "trimming" beam
Third: hit cut-plane button
Hi Renato , and the others
With 2 questions I synthetize in 1: 1 Rexroth profile structure (why not)
In view of the result it does not
In truth not at all, I think I have too much to ask the machine
So I cheated, I used a beam H which was used to cut the profile at 45 °
But that spawned me 1 alien, that had to explode 2 times before getting the result there
- Rexroth1.FCStd
- (438.67 KiB) Downloaded 44 times
Aaaah, there are some tiny little openings...
