Hi all,
I was working on a new model and suddenly everything disappeared from the screen.
I remember i was adding a fillet and saved my work...
I tried to delete the last part i worked on, but no change..
Any guess ?
Version: 0.17.12539 (Git)
Hash: adc24f8c8ffb81ce5b85af9ac6ed67054ae0030d
Python version: 2.7.8
OCC version: 7.1.0
Locale: French/France (fr_FR)
Thanks,
Model not anymore displayed .
- Battery CR2032-VCN.FCStd
- (116.07 KiB) Downloaded 37 times
Re: Model not anymore displayed .
Most commonly it's just the item is out of the view window, or zoomed way out, try clicking on a standard view angle and zoom fit all. I am on my phone so I can't check your file just now.
I assume that you have the item not hidden, check it's status in treeview. Also if you are working in PartDesign WB, then only the last feature should be set visible, deleting the last feature, e.g. your chamfer, doesn't change the visibility setting of the previous feature, you have to do that manually by right clicking in treeview.
Hi, thanks for the suggestions.
No, it's not a visibility problem.. I tried everything within my knowledge..
Perhaps can you try to load the attaced model and see how it's reacts ?
Thanks,
Thanks,
Hi, I expanded the tree view and the only thing I had to do is to make the things visible I want to see and make invisible the things I do not want to see. Visible must be:
- Part
- The three bodies named: Body Pin- and Pin+
- The last pad, pocket or fillet in the body
Visibility can be changed in the tree view by selecting the item and push the space bar
- Part
Hi Willem,
Thanks quite strange, because it doesn't work for me !
I have the same tree and visibilities, and nothing happens !
Will try this morning on another computer and 32bit version at office...
Thanks for the try, at least my model is not broken.
Patrick,
Patrick,
Same results on the office computer .. OS: Windows 7
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
OCC version: 7.0.0
OCC version: 7.0.0
Hi, did you also push the "fit" button
Re: Model not anymore displayed . [Solved]
Willem,
You made my day !! That did it...
I never used this button.
Shame on me...
Thanks !
Shame on me...
Thanks !
