[FEM] create NSET/ELSET from GUI?
reox
Postby reox » Mon Nov 13, 2017 6:09 pm
I like to have certain faces/edges of a body as an NSET or ELSET in my input deck file.
Is it possible to create such sets from the GUI?
edit: just found the Node set tool: https://www.youtube.com/watch?v=UtCmciD ... e=youtu.be
But the selected nodes are not in my .inp file? Also I do not understand how I am able to select a face with the tool... Selecting a volume with the poly tools work though.
Here are the steps I do:
* Create a mesh with gmsh, as netgen does not work...
* Go to Node Set
* Select "Surface"
* Select "pick" (I also tried to tick "add", same effect)
* select a node
* console says things like:
Picked Element:0 Face:1
Picked Element:1425 Face:2
Picked Element:1052 Face:1
* The number of nodes is still 0
* also selecting the object in python console gives set([])
I think there is also a bug: If you say "Surface" in the node set tool but then close the tool, you are stuck with the selection filter until you restart FreeCAD.
OS: Debian GNU/Linux testing (buster)
Version: 0.17.12570 (Git)
Build type: None
Hash: b01c503c2cb37b2ed4fb848b0f495f599a7b179f
Python version: 2.7.14
OCC version: 7.1.0
Locale: German/Austria (de_AT)
UR_
Re: [FEM] create NSET/ELSET from GUI?
Postby UR_ » Mon Nov 13, 2017 11:04 pm
I know just one workaround for exporting a NSET, but it's not quick nevertheless dirty :lol:
For example using 3D beam analysis from FreeCAD's startpage.
Constraint displacement generates NSET
Toolbar constraint displacement.png (23.54 KiB) Viewed 936 times
selected face.png (8.23 KiB) Viewed 936 times
relax face.png (19.68 KiB) Viewed 936 times
And you will get a .inp-file sequence starting with line 348:
** Node sets for prescribed displacement constraint
** written by write_node_sets_constraints_displacement function
** FemConstraintDisplacement
*NSET,NSET=FemConstraintDisplacement
64,
1,
2,
3,
4,
102,
49,
88,
100,
188,
189,
190,
191,
Better rename NSET to avoid some confusion :lol:
Please delete this sequence, starting with line 399:
** Displacement constraint applied
** written by write_constraints_displacement function
*BOUNDARY
As promised, not quick but dirty. Hope bernd has a more sophisticated, python based workflow ;)
reox
Postby reox » Tue Nov 14, 2017 9:32 am
yes, that was the same thing I thought about before I saw the Node Set tool. But it looks like the Node Set tool needs some extra love and care...
It is also interesting, that a fixed constraint creates a NSET but a CLOAD puts all nodes into the section directly. For a better overview in the file, I would have created a NSET as well...
bernd
Postby bernd » Tue Nov 14, 2017 10:43 am
If you need the nset or esets in the inp file the mesh group tool would be the way to go. With this tool you could create mesh groups.
The problem is the inp writer from FreeCAD does not support groups. You could export to unv and use some other software to convert the unv with groups into an inp. Support for groups is on my ToDo but the inp writter is in C++ and my C++ is rather poor.
If you really need it and know Python you may could make this as an extra tool or macro. First write the mesh to the file (one line of Python) and second write the mesh groups by python (code could be copied from constraint writer).
The node set tool is an very old tool which was started before I came to the project but never was finished.
bernd
bernd
Postby bernd » Tue Nov 14, 2017 11:36 am
Check the input file of the 3D example. The node loads are different. This because if you apply a face load to a lot of elements faces of the mesh the node loads inside each element are different due to the element notification. Thus for CLOAD the nset is not used.
bernd
bernd
Postby bernd » Tue Nov 14, 2017 2:54 pm
The CLOAD vs. DLOAD topic ... https://forum.freecadweb.org/viewtopic.php?f=18&t=10692 I di I did not expect to find it that fast ... Just read posts on the first two pages and you will understand why nset is not used at CLOAD.
Cheers Bernd
reox
Postby reox » Tue Nov 14, 2017 2:59 pm
Cheers Bernd
ah, yes you are right.
for the other things: I'll take a look at the mesh groups and the macro approach. thanks!
bernd
Postby bernd » Tue Nov 14, 2017 3:09 pm
If you have any questions just post. Best is to post any question dedicated to FEM in FEM part of the forum.
bernd
bernd
Postby bernd » Tue Nov 14, 2017 3:13 pm
write a FEM mesh to inp file by python:
https://github.com/FreeCAD/FreeCAD/blob ... Ccx.py#L80
How to write the groups as sets into the inp file. Best to study the fixed constraint code
https://github.com/FreeCAD/FreeCAD/blob ... Ccx.py#L93 and the method called by this ...
bernd
Postby bernd » Tue Nov 14, 2017 4:46 pm
Damn the second one is totally wrong because if you use the mesh group tool the mesh groups are inside the mesh in FreeCAD already. Means you do not need to get them again. You just need to get the group data out of the mesh in FreeCAD FEM and write it to the inp file.
