Cross section river profiles
I'm absolutely new in FreeCAD. Formerly I only used GIS software and no CAD, but I'm very experienced in GIS.
So my problem is I have a mapping job for meassuring cross sections of a river bed. The customer wants somthing like this from me for each cross section profile: What I've meassured were the XYZ-coordinates of each point in ETRS89/UTM Zone 32N. The data which I gathered with the device is stored in a CSV file with the headers: name,x,y,z. So what I've tried first is to import the CSV in QGIS and saved it as a SHP and also as a DXF and GPX with included z coordinates. I've successfully imported the points from the DXF in FreeCAD. They are displayed in the right realation to each other and also with their respective Z values. Unfortunately the points were not imported in the right scale. Were a point pair in QGIS has a distance of 1.4 m the distance in FreeCAD has around 0.34 m. How I can configure the right scale?
I also tried to import the data with the Geo Data workbench CSV import tool. I get the error "Index error: list index out of range". The same error appears with the GPX import tool. Do you know how to fix that error?
What I also tried is to connect the wrong scaled points with multiple-point DrawWires and endpoint snapping. The lines snaps on the points, but not on their z value. What is wrong?
So what idea do you have to get such cross section profiles from my spatial measuring data shown above in FreeCAD? Or is it impossible?
- microelly2
Re: Cross section river profiles
welcome to the forum,
can you send me your data as pm for debugging the geodat import?
quick and dirty...
the area of the riverbed is approx 43 m^2.
Thomas
Thomas
thschrader, thank you for your reply. It's a nice feature.
But do you also know how to "draw" such profile by myself from my data in FreeCAD?
Sorry, no. As I said above: quick and dirty...CanisLupus wrote: ↑Tue Dec 05, 2017 7:08 pm thschrader, thank you for your reply. It's a nice feature.
It certainly can be done, there will be several ways.CanisLupus wrote: ↑Tue Dec 05, 2017 7:08 pm thschrader, thank you for your reply. It's a nice feature.
Can you please post your version data in the manner explain in the forum rules link above. Also please post your CVS file or if privacy is an issue perhaps just post a subset of the data, perhaps for example just one cross section.
I suspect the name column is causing import errors and possibly the data will import if it is just a list of xyz. It could also be imported as a point cloud in points wb. Then all the points would be one item ...a point cloud rather than a series of individual points.
I think you mean Draft WB Wire. The problem withz will be your working plane, make sure snap to working plane is off.CanisLupus wrote: ↑Thu Nov 30, 2017 2:27 pm What I also tried is to connect the wrong scaled points with multiple-point DrawWires and endpoint snapping. The lines snaps on the points, but not on their z value. What is wrong?
Version Info:
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Attached some example data as CSV.
The naming of each dataset:
– first number digit means the cross section number
– q means "querprofil" in german = cross section
- last number digits mean serial numbers for each measured point in its respective cross section
- example_data.csv
- (2.03 KiB) Downloaded 78 times
I'm trying import data and draw with python.
The first data, named '1qp01', x value has some problem. It's very far from x's data group.
{edit} fixed import Draft
import Arch
import Draft
import csv
from FreeCAD import Vector
path = 'D:\\Data\\RiverCrossSection\\'
fName = path+'example_data.csv'
CrossSection = {}
with open(fName, 'rb') as csvfile:
data = csv.reader(csvfile, delimiter=',')
count = 1
for row in data:
#Msg(row); Msg('\n')
if count>1:
name = row[0]
str1 = name.split('q')
id = str1[0]
pointName = str1[1]
x = row[1]
y = row[2]
z = row[3]
pointData = (x,y,z)
if CrossSection.has_key(id):
#CrossSection[id].append( pointData )
CrossSection[id][pointName]= pointData
else:
pointData = {pointName:pointData}
CrossSection[id] = pointData
count+=1
Msg(CrossSection); Msg('\n')
minX = 10000000
minY = 10000000
minZ = 10000000
for iSection in CrossSection:
#Msg(iSection); Msg('\n\n')
#Msg(CrossSection[iSection]); Msg('\n\n')
for iPoint in CrossSection[iSection]:
#Msg(CrossSection[iSection][iPoint]); Msg('\n')
x = float( CrossSection[iSection][iPoint][0] )
y = float( CrossSection[iSection][iPoint][1] )
z = float( CrossSection[iSection][iPoint][2] )
if x<minX: minX = x
if y<minY: minY = y
if z<minZ: minZ = z
#Msg('\n')
Msg('%g , %g , %g\n'%(minX, minY,minZ) )
datumElev = minZ - 1.0
doc = FreeCAD.ActiveDocument
doc.addObject("App::DocumentObjectGroup","Section%s"%iSection)
#for i in range(0,len(CrossSection[iSection])+1):
group = doc.getObjectsByLabel("Section%s"%iSection)[0]
Pnt2 = Vector( CrossSection[iSection][iPoint] )
Pnt2[0]-=minX; Pnt2[1]-=minY; Pnt2[2]-= minZ
Pnt1 = Vector( CrossSection[iSection][iPoint] )
Pnt1[0]-=minX; Pnt1[1]-=minY; Pnt1[2]-= minZ
Pnt1[2] = -2.
#Msg(Pnt1); Msg(Pnt2); Msg('\n')
points = [Pnt1*1000 , Pnt2*1000]
line = Draft.makeWire(points)
line.Label = "%sq%s"%(iSection, iPoint)
group.addObject(line)
for i in range(1,len(CrossSection[iSection])):
name1 = 'p%02d'%i
name2 = 'p%02d'%(i+1)
Pnt1 = Vector( CrossSection[iSection][name1] )
Pnt2 = Vector( CrossSection[iSection][name2] )
line.Label = "%s_%s"%(name1, name2)
Hello chakkree,
many thank you for your effort!
I've tested your code, it worked except the last two for-loops. I will get the following errors:
Do I need some more libaries? Or I have to change a name?
PS: I've uploaded a new CSV, because there were wrong values.
... #for i in range(0,len(CrossSection[iSection])+1):
... group = doc.getObjectsByLabel("Section%s"%iSection)[0]
... for iPoint in CrossSection[iSection]:
... Pnt2 = Vector( CrossSection[iSection][iPoint] )
... Pnt2[0]-=minX; Pnt2[1]-=minY; Pnt2[2]-= minZ
... Pnt1 = Vector( CrossSection[iSection][iPoint] )
... Pnt1[0]-=minX; Pnt1[1]-=minY; Pnt1[2]-= minZ
... Pnt1[2] = -2.
... #Msg(Pnt1); Msg(Pnt2); Msg('\n')
... points = [Pnt1*1000 , Pnt2*1000]
... line = Draft.makeWire(points)
... line.Label = "%sq%s"%(iSection, iPoint)
... group.addObject(line)
File "<input>", line 13, in <module>
NameError: name 'Draft' is not defined
... for i in range(1,len(CrossSection[iSection])):
... name1 = 'p%02d'%i
... name2 = 'p%02d'%(i+1)
... Pnt1 = Vector( CrossSection[iSection][name1] )
... Pnt2 = Vector( CrossSection[iSection][name2] )
... line.Label = "%s_%s"%(name1, name2)
File "<input>", line 11, in <module>
- microelly2
Add the lineCanisLupus wrote: ↑Tue Dec 12, 2017 10:22 am I will get the following errors:
import Draft
