[Solved] Sketch Angle Constraints Wrong Reference Reading?
paullee
Postby paullee » Sun Dec 24, 2017 3:37 am
Hi, puzzling for a while. There are a few angle Constraints in the sketch below as reference.
A point move around and the angles update as reference.
At some particular cases, see screencapture for the one captured, a reading return 11.76 deg though it is apparently 2 lines bigger than 90 degrees. The reference provide wrong reading frustrate subsequent calculation / expression.
Interestingly, when the file is untouched and re-opened, it reads (I am not sure if re-opening the sketch w/o closing the file do the same thing) -168.xx degree which is the correct reading. Anything missing or could be done? Thanks.
Screenshot from 2017-12-24 10-57-58.png (177 KiB) Viewed 1360 times
Screenshot from 2017-12-24 11-00-42.png (174.61 KiB) Viewed 1360 times
[EDIT]
OS: Linux
Version: 0.17.12852 (Git)
Build type: None
Hash: 8e3b2d7e84924444bc219133a7e0bbd07413cf4f
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Test _ Sketch _ Angle Constraint Puzzle.fcstd
(5.25 KiB) Downloaded 11 times
Re: Sketch Angle Constraints Wrong Reference Reading?
Postby chrisb » Sun Dec 24, 2017 6:41 am
Which version do you use? Did you try a Force_Recompute (0.16) or the built-in recompute for the whole document (0.17)?
Postby chrisb » Sun Dec 24, 2017 6:56 am
Here everything seems to be ok. Which point are you actually dragging?
Have you checked the "Improve solving while dragging"-box in the preferences?
OS: Mac OS X
Version: 0.17.12851 (Git)
Branch: (HEAD detached at 394ae19)
Hash: 394ae197fbe082ee32321b60bcae579262fa6df0
Python version: 2.7.14
Qt version: 5.6.2
OCC version: 7.1.0
OS: Mac OS X
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.11
OCC version: 6.8.0.oce-0.17
paullee
Postby paullee » Sun Dec 24, 2017 10:14 am
Oops, forgot the version
on mobile now, lateest Appimage git 12852
it is random, just drag the central point with a bunch of construction lines attached to it.
lot of time constraint a4 has problem
Note when it is Wong,. It report the complementary angle i.e.,-ve (180 - correct angle)
Postby chrisb » Sun Dec 24, 2017 10:43 am
I can reproduce it when moving the center - before I tried only the two points. The wrong angle is corrected as soon as I hit the recompute button.
Postby chrisb » Sun Dec 24, 2017 10:45 am
Saving triggers the recompute as well. After closing and reopening the sketch it shows the correct angle. Is this the same at yours?
paullee
Postby paullee » Sun Dec 24, 2017 10:54 am
not always corrected upon recompute in my version / test.
Afterall, should be bug, no good need recompute especially as those reference datum is refered in other
expression, giving wrong result unknown to user.
Postby chrisb » Sun Dec 24, 2017 11:12 am
If it's not corrected at the closing recompute it's a bug.
paullee
Postby paullee » Sun Dec 24, 2017 5:11 pm
Site Admin
Postby wmayer » Fri Dec 29, 2017 2:35 pm
There a few more oddities:
  • when deleting the angle constraint (Constraint23) then an error message comes up:
    Duplicate constraint not allowed
  • when selecting the two edges of the deleted angle constrained and trying to add a new constraint results into a heap corruption
