PDN Sweep
Re: PDN Sweep
I liked the idea:
I call firsties!!! I have also been officially the first user to disable this functionality
Re: PDN Sweep
That's a striking argument.
Re: PDN Sweep
@abdullah - I'll offer an argument for why not:
Because it is still usually faster and easier to select the endpoints if you don't try to select them by clicking directly on them. Try using Box Selection for selecting those tiny endpoints instead....
Good to see you back and busy again!
Re: PDN Sweep
More or less it comes down to box selection. You quickly lose the patience to be precise. It would cause too much stress being set to such precision during the long hours.
Exactly!I call firsties!!! I have also been officially the first user to disable this functionality
As for the pop-up. OK therefore some feel strongly about it and something does get deleted. Therefore one more pop-up won't make the world stop from spinning. As for the execution. I will be honest. If i look at that settings section image you posted for general Sketcher preferences. One would likely need a good manual (or i guess a good number of verbose pop-ups) for being able to figure it all out. Therefore if you ever decide to work on this more. I see this as a better solution. Pop-up itself should have the checkbox. That would make it much easier for the end user to turn it off. In preferences under General there should be only one checkbox that sets the global parameter. Developers adding different type of pop-ups can later decide to respect or not to respect the global setting by checking the parameter setting.
Or something like that i guess.
Re: PDN Sweep
It is true. It will also depend on how many other selectable things you get around and within the box areabejant wrote: ↑Thu Jan 25, 2018 8:21 pm @abdullah - I'll offer an argument for why not:
BTW, It is only me, or the box selection works ok when deployed bottom-left to top-right, but poorly when deployed top-right to bottom left?
We have wonderful wiki manuals and an array of power users helping in the help forum... I do not know what could be wrong
Now seriously. One of the magic things behind FC is that defaults work just fine. I think that when a user starts to be fed up of the pop-up he already has a good grasp of FC and where to search, where/whom to ask. But...
It is always possible to improve these things. I might work someday on that, but my preferences are more into new functionality and bug fixing. I think it is where most of the difference is made. Let's see...triplus wrote: ↑Thu Jan 25, 2018 11:50 pm Therefore if you ever decide to work on this more. I see this as a better solution. Pop-up itself should have the checkbox. That would make it much easier for the end user to turn it off. In preferences under General there should be only one checkbox that sets the global parameter. Developers adding different type of pop-ups can later decide to respect or not to respect the global setting by checking the parameter setting.
Re: PDN Sweep
It may actually be intended. From right to left seems to be a "crossing" selection, everything crossed by the box gets selected. Sometimes it can be really useful. FYI this is a type of selection that is supported in other CAD software.
EDIT: chrisb, you need to be faster on the keyboard man!
Re: PDN Sweep
It's not a bug, it's a feature. From left to right all elements are selected which are completely covered by the selection rectangle. From right to left all elements are selected that are touched by the rectangle.
Edit: Ok, fast typing Normand, ...
Re: PDN Sweep
I did not see that one coming. Ok, feature it is. Thanks for the lesson. Just another example of where is the fastest and more accurate place to get information about that thing of FC you do not understand
Re: PDN Sweep
OT: Maybe there should be a symbol that shows up at the corner of the bounding box depending on the directionality (this way it gives the end-user an understanding that they are in a different selection mode?
