SVG import segfault
SVG import segfault
When I try to import an SVG, freecad immediately segfaults.
openat(AT_FDCWD, "/path-to-file.svg", O_RDONLY) = 27
fstat(27, {st_mode=S_IFREG|0644, st_size=2234752, ...}) = 0
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x3a9} ---
write(2, "\33[1;31m", 7) = 7
write(2, "Program received signal SIGSEGV,"..., 53Program received signal SIGSEGV, Segmentation fault.
) = 53
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x37140) [0x7fd97f382140]
#1 /lib/x86_64-linux-gnu/libexpat.so.1(XML_SetHashSalt+0x1b) [0x7fd976c411cb]
#2 /usr/lib/python2.7/lib-dynload/pyexpat.x86_64-linux-gnu.so(+0x6968) [0x7fd90487a968]
Nobody else seems to have this problem, am I missing some dependencies? (ubuntu 17.10, freecad-daily just updated, but same behavior on freecad 0.16)
) = 53
Re: SVG import segfault
Hi, welcome to the forum
Can you upload your SVG file. I do not know with what program it is made.
With a bad SVG file I try to open it in Inkscape and when that succeeds I save it as a normal SVG, very often this trick works
Doesn't help. The -normal.svg is saved from inkscape.
Even if there is something wrong with the SVG, why the segfault?
- Svg_example4-normal.svg
- (808 Bytes) Downloaded 180 times
- Svg_example4.svg
- (292 Bytes) Downloaded 183 times
Hi, the SVG file has no problems on my system.
OS: Ubuntu 16.04.3 LTS
Version: 0.17.12920 (Git)
Build type: None
Hash: 8faa9f38bb70a598afc2bc39ea1645d416ab057e
Python version: 2.7.12
OCC version: 7.1.0
Build type: None
OCC version: 7.1.0
This is why we ask to actually paste the contents of Help > About FreeCAD > copy to clipboard
to ascertain this point exactly. Per the forum guidelines.
I did read the guidlines, but somehow missed that, sorry.
OS: Ubuntu 17.10
Build type: None
Python version: 2.7.14
OCC version: 7.1.0
Locale: Swedish/Sweden (sv_SE)
But in this case, does this really help?
OS: Ubuntu 17.10
Build type: None
OCC version: 7.1.0
libexpat is the problem.
On Ubuntu 17.10 artful, the libexpat package version is 2.2.3-1 (https://packages.ubuntu.com/artful/libexpat1). Crash on SVG import.
Manually installing libexpat-2.1.0-7ubuntu0.16.04.3 fixes the problem. No crash.
Steps to reproduce:
1) Command-line start `freecad Svg_example4.svg`
2) Segfault
2) Segfault
