Hi all!
Haven't seen a similar issue in the bug tracker, so I'm posting here.
Steps to reproduce:
1. Open the attached file:
2. Change a dimension in Sketch008 placed inside Pad002 (eg 139 to 140)
3. Now Sketch_LCD (inside LCD pocket) is invalid (red exclamation mark)
4. Remove external edges from Sketch_LCD, now "Sketch contains conflicting constraints" message is visible.
5. Close the sketch.
6. Try reopen the sketch. Now "Do you want to open the validation tool? The sketch is invalid and cannot be edited"
7. Open the validation tool.
8. Find and fix 4 missing coincidences.
9. The sketch is still invalid, but now tooltip in the tree view says "No planar face in the AttachEngine3D::calculateAttachedPlacement()!" instead of "Error"
OS: Ubuntu 17.10
Version: 0.17.13050 (Git)
Build type: None
Hash: 305a567819522a336bd16a6c694772be2f56af47
Python version: 2.7.14
OCC version: 7.1.0
Locale: Polish/Poland (pl_PL)
I made this submission to help an user in the Polish subforum https://forum.freecadweb.org/viewtopic. ... 68#p210168
[Bug] Changing a dimension in a sketch makes another sketch invalid (No planar face in the AttachEngine3D)
- DeepSOIC
Re: [Bug] Changing a dimension in a sketch makes another sketch invalid (No planar face in the AttachEngine3D)
classic toponaming problem. Thickness afaik is especially prone to randomizing element numbering. All links in the last sketch are to Thickness.
Sketch_LCD's support should be changed to a baseplane (XY), and subelements can be rerouted to link directly to Sketch008. This should make the model MUCH more robust.
==== Sketch_LCD uses: ====
Thickness001 as ExternalGeometry (Sublink)
Thickness001 as Support (Sublink)
====Links to Sketch_LCD:====
Body001.Group (Child)
Pocket005.Profile (Sublink)
Thanks. I think, at this point i better to use Pad+Pocket combo instead of thickness when it's possible.
