How to turn off (disable) Numpad navigation?
On projects, where are a lot of direct data editing in a fields on Property tab, changing a view
instead of changing data while pressing digit on already selected (!) field if boring.
Where it is possible to switch it off?
I'll do a shortcut to on/off it by myself, if someone shows me there.
Yours,
Eugenijus.
Yours,
Eugenijus.
Re: How to turn off (disable) Numpad navigation?
I don't quite understand the issue. Is the problem that you have to leave an input field in the DataTab before FreeCAD recomputes? I'm afraid you cannot configure this behaviour.
Or is it that you don't want a recompute to be performed after each single change of a property? This is soometimes a problem on huge models because the recompute takes very long. In this case you can suppress the recompute. In the right-click-menu on the document in the tree you have the entry "Skip recomputes". You will then have to do the recompute yourself.
[grin]
It is because of my English.
The question is about disabling of changing a View using NumPad. Temporary or at all - not important.
Let me try to explain once more:
If I want to enter some value to a field on Property tab, let's say to change Z position of something, while pressing a digit on NumPad, I sometimes get changing of View instead of entering the value.
Hope you understand now...
Yours,
Eugenijus.
Yours,
Eugenijus.
Hi Eugenijus.
Numbers (on numpad) can be used to change View in 3D. For example 1 will set the view to Front. What is likely happening is when you select something in 3D the properties of the selection are made visible in the sidebar. And some property is highlighted. That likely lead you to believe you can start entering the value to change the property value. AFAIK you need to explicitly click on the property value first to start the editing mode (with this you change the focus). And after you can change the value.
Thank you.
I already knew the fact I can change the view using NumPad.
The question is: How to DISABLE it.
Yours,
Eugenijus.
Yours,
Eugenijus.
AFAIK you can't ATM. That is current workflow was likely selected due to the fact when you select something in 3D View user should still be able to change view (and use other shortcuts). And that is why focus is likely preserved on 3D View (and is not automatically set on property editor). I am guessing for alternative workflow somebody would need to find the suggestion reasonable and implement such feature first.
So, only one solution at the moment is to use numeric keys on main keyboard, not on NumPad.
I will, 'cause I must [smile].
Yours,
Eugenijus.
Yours,
Eugenijus.
You could open a Feature Request on the bugtracker, if you want.
No, you must simply click with the mouse on the input field as triplus suggests above. This will change the "focus" and the numpad will take input as you expect.
Can you give a simple step by step how your arrive at your problem? I've encountered this before but can't replicate now. Maybe then one of our cracker-jack video producers can make a visual example.
"fight the good fight"
- microelly2
Hello Eugenijus.
which version of FreeCAD you use?
for me it works fine on the num pad
0.17
0.17
