I've got two female threads (one GL32 and one 1/2" BSPP) which function as a converter. In order to be 3D printable, I assume that I need to connect the two ends by creating a hollow cone (see pic).
How would I go about it?
Thanks!
Connecting two internal female threads
- Hose Connector.FCStd
- (705.48 KiB) Downloaded 48 times
Re: Connecting two internal female threads
Part->Loft is your friend.
your file have some issues, no walls only threads.
One thread has a helical end. Would the Loft still be the right tool?
You could do it with a loft going down far enough or with a ring on top of the helix.and the loft on top of the ring.
from my expirience you need something like this.
2-revolve profile 360 degrees,
3-make Gl32 thread,
4-make BSPP 1/2" thread,
5-check&3D print.
It is my way, there is may be another one.
p.s. those chamfered inner diameters simulate the threads.
1-draw a profile of the part,2-revolve profile 360 degrees,
3-make Gl32 thread,
5-check&3D print.
- hcp2.png (233.54 KiB) Viewed 980 times
