Spreadsheet Inserting Row Cause Crash - FC Daily v0.17
3DME
Postby 3DME » Mon Feb 26, 2018 9:47 am
Problem Description:
I am having problems inserting rows in a spreadsheet,
Inserting Row Causes FC Daily v0.17 to crash
To re-create the problem:
Open the project,
select the spreadsheet workbench,
open the spreadsheet,
right-click mouse on row-2 and select insert row, then FreeCad crashes.
Note:
Alias in the spreadsheet are highlighted in yellow.
Help --> About FreeCAD, Version Info:
OS: Ubuntu 16.04.4 LTS
Version: 0.17.13331 (Git)
Build type: None
Hash: e5ef0f532d7e733c581d587cb1c4796237912e03
Python version: 2.7.12
OCC version: 7.1.0
Thank You
Spredsheet_1X_9PTS-Grouped_Cuts.fcstd
(32.18 KiB) Downloaded 17 times
GeneFC
Re: Spreadsheet Inserting Row Cause Crash - FC Daily v0.17
Postby GeneFC » Mon Feb 26, 2018 2:53 pm
I realize this response may not help very much, but I had no difficulty in following your instructions with no crash. Insertion worked as expected.
OS: Windows 7
Python version: 2.7.14
OCC version: 7.1.0
The typical suggestion is to try again and/or to remove the configuration files system.cfg and user.cfg and let them regenerate. (I usually save a copy of those files so I do not lose customizations if those files were not the cause of the problem.)
Gene
NormandC
Postby NormandC » Mon Feb 26, 2018 5:29 pm
Please check the Debugging documentation and provide a backtrace. Even without compiling a debug build, this may provide useful info.
triplus
Postby triplus » Mon Feb 26, 2018 10:08 pm
Hi @3DME.
On a same system and FreeCAD version as you use i can confirm something is not working as it should. The Row doesn't get inserted. And if i try a few times FreeCAD crash will occur.
3DME
Postby 3DME » Tue Feb 27, 2018 8:30 am
Hello NormandC,
As recommended I followed the link you provided “https://www.freecadweb.org/wiki/Debugging
After reading the instructions for Linux Debugging, I performed the following:
Test Framework
Ran the “Test framework” and it passed,.
Attached file “Freecad-Test Framework-OK.png” contains the results for the Test framework.
Debugging
Opened terminal and entered :
cd '/usr/lib/freecad-daily/bin/'
gdb FreeCAD
then
(gdb) handle SIG33 noprint nostop
(gdb) run
I then opened my FreeCad project and attempted to insert a new row at row-2 in the spreadsheet, the insert failed as expected.
Attached file ”FreeCad_Debug_Terminal_text.txt” contains the debug results.
Hope this information is helpful.
Thank you.
(4.29 KiB) Downloaded 12 times
Freecad-Test Framework-OK.png (29.41 KiB) Viewed 1070 times
eivindkvedalen
Postby eivindkvedalen » Thu Mar 01, 2018 12:56 am
Open the project,
I've confirmed this bug, please register it in the bug tracker.
EDIT: The crash happens because of a merged cell, for some unknown reason. As a work-around, split your merged cell to avoid the crash.
Eivind
3DME
Postby 3DME » Thu Mar 01, 2018 6:50 am
Bug Tracker Login Problem:
I am trying to enter/register this to the Bug Tracker.
However, I was not successful login onto the mantis BUG TRACKER.
I get this message:
“Your account may be disabled or blocked or the username/password you entered is incorrect.”
My user name and password are valid, I use them to logo onto this forum.
Does the bug tracker use a different user name/password list?
Postby chrisb » Thu Mar 01, 2018 6:53 am
You have to register separatly. Of course it is sensible to use the same username. So that comments on both sides can be matched with the posters.
Postby Kunda1 » Tue Jul 31, 2018 11:00 pm
@3DME please mark this thread as [Solved] per git commit d2f9ab6a111975fce69c7f29bf3b
Thanks
