Ticket #3379 - [Expressions] Cannot reference driven constraint
Postby chrisb » Tue Mar 13, 2018 10:12 pm
In the attached model I have a sketch with a normal (driving, red) and a driven constraint (blue).
I can use the normal constrant in subsequent steps within Expressions but not the driven. I am pretty sure that this worked before.
I am aware that it does not work within the same sketch to reference the driven constraints.
Bildschirmfoto 2018-03-13 um 23.06.36.png (18.97 KiB) Viewed 889 times
expressionDriven.FCStd
(6.58 KiB) Downloaded 16 times
Reason: Updated thread title with ticket number
sgrogan
Re: Cannot reference driven constraint
Postby sgrogan » Tue Mar 13, 2018 10:19 pm
Are you setting up a circular dependency elsewhere?
Postby chrisb » Tue Mar 13, 2018 10:26 pm
No, and the model is simple enough to be very sure.
I found that the problem is the name of the constraint. If I name it "y" instead of "h" it works as expected.
Willem
Postby Willem » Tue Mar 13, 2018 10:37 pm
I can confirm the problem. In other sketches you can not reference to the construction dimension.
The message appears: Failes to parse expression
My system
OS: Ubuntu 16.04.4 LTS
Version: 0.17.13387 (Git)
Build type: None
Hash: c5f4079252b11e3c54cd603be7d3697fa9f9d922
Python version: 2.7.12
OCC version: 7.1.0
Postby chrisb » Tue Mar 13, 2018 10:42 pm
Does my example work on your system if you rename "h" to "y"? Can you reference that like I can?
Willem
Postby Willem » Tue Mar 13, 2018 11:17 pm
Hi, I can confirm this issue. Renaming from "h" to "y" makes the expression valid. Renaming to "rad" makes the expression also invalid. Perhaps there are more values to be found for making the expression invalid. Is this a bug?
Postby chrisb » Wed Mar 14, 2018 12:25 am
eivindkvedalen wrote: Eivind
Care to weigh in?
eivindkvedalen
Postby eivindkvedalen » Fri Mar 16, 2018 1:12 pm
Care to weigh in?
Both h and rad are reserved, as they are also units (h = hour, rad = radians). Even if they are unambiguous when used as a name (like Contraints.h), the parser does not understand that, as it parses word by word, and h and rad are immediately identified as units.
Eivind
NormandC
Postby NormandC » Fri Mar 16, 2018 4:47 pm
a driven constraint
This is a contradiction in terms. If it is driven, it cannot be a constraint.
GeneFC
Postby GeneFC » Fri Mar 16, 2018 5:13 pm
The official term, as shown in the tool tip, is "reference constraint." Of course it is really a "driven dimension" or a "reference dimension."
Gene
