I am manipulating a 2d profile cut from the intersection of a shape on a plane. I have a working method, but it feels hacked, and I was curious if anyone had a better suggestion.
Currently the Cut-Shape is used to cut its inverse--a Bottom-Shape--which I move relative to the top-Shape, taking iterative cuts of the Top-Shape. The drawback is that where the cuts have sharp changes, vertical errors creep in, relative to the step size. It also hacks up any horizontal edges cut by the Bottom-Shape.
The 1st image shows a section where the contour is sharp, but has a flat top, so it hacks up the horizontal line, but introduces no errors...
The 2nd image shows a section where an arc cuts an offset plane to spread the edges around the arc. The vertexes of the iterative cuts are visible.
Thanks,
Josh
Version: 0.17.13387 (Git)
Hash: c5f4079252b11e3c54cd603be7d3697fa9f9d922
Python version: 2.7.14
OCC version: 7.1.0
Iterative cutting?
Iterative cutting?
- IterativeCutResult2.png (160.67 KiB) Viewed 387 times
- IterativeCutResult.png (150.52 KiB) Viewed 387 times
