triplus wrote: ↑Thu Mar 29, 2018 9:16 pmNo it's not that. POV-Ray (used through FreeCAD or as a standalone) doesn't like non-ASCII characters in the path. That is why i said just do the test by using the home folder. To confirm if it is working in general or not.
Likely this is the culprit yes. Something isn't set up correctly.I explicitly created this root-level folder specifically for such tasks, and set appropriately liberal permissions.
So I've now tried it for you, specifying it into the home folder's Desktop, and the (non-)result was exactly the same.
You also seem to doubt ASCII characters. Erm, looking past the format-mangling caused by phpBB's apparent inability to combine both monospace-font and code tags, they sure all look like ASCII-printables to me :
echo '/FreeCAD_Output/renderedoutput001.png' | od -tdCac -w16
0000000 47 70 114 101 101 67 65 68 95 79 117 116 112 117 116 47
/ F r e e C A D _ O u t p u t /
0000020 114 101 110 100 101 114 101 100 111 117 116 112 117 116 48 48
r e n d e r e d o u t p u t 0 0
0000040 49 46 112 110 103 10
1 . p n g nl
1 . p n g \n
0000046
I wholeheartedly agree that the problem most likely stems from "something isn't set up correctly" but my suspicion is that it's something been omitted from the Tutorial. A pre-requisite..? An assumption..?
For example, just off the top of my head, I'm now wondering whether you're all assuming modern fast hardware with current OpenGL or suchlike, you know, those component type things that are easily overlooked, and which haven't actually been listed as a pre-requisite..?
FWIW :
Graphics: Card: Intel 4 Series Integrated Graphics Controller
Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa) Resolution: 1280x1024@75.02hz
GLX Renderer: Mesa DRI Intel Q45/Q43 GLX Version: 2.1 Mesa 17.2.4
Thanks anyway.
