Tiled view imposed
alberich
Tiled view imposed
Post by alberich »
Latest, for me, FC daily:
OS: Ubuntu 16.04.4 LTS
Version: 0.17.13509 (Git)
Build type: None
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.12
OCC version: 7.1.0
Every time I import a new part into Assembly I get jumped from full window to tiled view and have to toggle back. Didn't happen with previous daily.
Edit: Update Parts causes the same jump to tiled view.
Re: Tiled view imposed
Post by NormandC »
alberich wrote: Sat Apr 07, 2018 12:53 pm Edit: Update Parts causes the same jump to tiled view.
Would you please give more details than that...
Detailed process to make it happen. Please.
alberich
Post by alberich »
I cooked up a minimal test case.
1. Create a Part - just a default cube
Save file.
2. Open new file. Select Assembly 2 WB
3. From Assembly 2 dropdown, click Import Part and select the above created bugTestCube. Upon import, display jumps to tiled
Post by NormandC »
Assembly2 is an external module that is not part of official FreeCAD. Its development has stopped because its author abandoned the project, and the person who took it up after him died last September (see announcement at the top). Nobody else claimed it. Therefore it is not currently fully compatible with v0.17.
I quoted your edit, thinking you were mentioning another way to get the bug, but without using Assembly2.
alberich
Post by alberich »
I hadn't realized Assy2 was orphaned. Nevertheless, this is a thing that worked properly up until this latest daily. Something happened between 13509 and the previous that caused it.
Btw, what, then, is the correct way to handle assembly in 0.17? I thought I had this grokked.
alberich
Post by alberich »
I switched from 0.17 daily to the 0.17 release version
Version: 0.17.13509 (Git) AppImage
Build type: None
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
and the problem is gone.
I consider the problem solved but I justed want to note that the release version uses Qt 4.8.6, vs 4.8.7 in the daily build I had been using.
triplus
Post by triplus »
alberich wrote: Sat Apr 07, 2018 3:39 pm I hadn't realized Assy2 was orphaned. Nevertheless, this is a thing that worked properly up until this latest daily.
Yes this part is usually a bit exaggerated. That is Assembly 2 workbench is known to work in both FreeCAD 0.16 and FreeCAD 0.17 (Py2/Qt4) just fine.
alberich wrote: Mon Apr 09, 2018 1:38 pm and the problem is gone.
Good to hear that.
