Need basic sketcher help, copying or duplicating shapes
lemonbug
Postby lemonbug » Fri Apr 13, 2018 5:02 pm
Hi.
How can I duplicate the curves on the left side of my sketch to the right? after I do that I would like to take the entire shape that we created on the top side and mirror it on the bottom. thanks
Screen Shot 2018-04-13 at 12.57.10 PM.png (81.18 KiB) Viewed 333 times
OS: Mac OS X
Version: 0.17.13509 (Git)
Branch: tag: 0.17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
Qt version: 5.10.1
OCC version: 7.2.0
Test.FCStd
(59.26 KiB) Downloaded 5 times
Willem
Re: Need basic sketcher help, copying or duplicating shapes
Postby Willem » Fri Apr 13, 2018 6:42 pm
Hi, the solution is
- Dimension and constrain the sketch
- make two arcs on the right side
- Constrain the arcs as equal
dbecad
Postby dbecad » Fri Apr 13, 2018 8:19 pm
You can also use the symmetry tool on the vertical/horizontal axis, but as Willem mentioned you would still have to apply equal constraints to the radius, borders and tangent constraints to the end segments to lock everything in place.
It's a too bad there are no "symmetry clone" tools to facilitate the process.
Cheers
symetry.FCStd
(4.69 KiB) Downloaded 3 times
lemonbug
Postby lemonbug » Fri Apr 13, 2018 9:27 pm
thanks. im trying to do this myself before opening your file. these arcs are really agitating me. i clearly don't under stand how to work with them well.
Cheers
lemonbug
Postby lemonbug » Fri Apr 13, 2018 9:43 pm
is there a way to put a construction line directly between two other lines ors points so I can use this as a line of symmetry?
lemonbug
Postby lemonbug » Fri Apr 13, 2018 10:03 pm
Given the arc on the left how do I mirror it to the point circled on the right? I selected the arc itself on the left, then the end point of the line, then the symmetric geometry button in sketcher. when i do this it shoots it way off to the right. i don't understand what it is referencing way over there. thanks
Screen Shot 2018-04-13 at 6.00.05 PM.png (111.08 KiB) Viewed 287 times
sgrogan
Postby sgrogan » Fri Apr 13, 2018 10:08 pm
It's mirroring about the point you selected last. Select your arc then the vertical line (center line) You should make the mirror line construction.
NormandC
Postby NormandC » Sat Apr 14, 2018 3:33 pm
Are you using v0.16 or v0.17?
In your screen capture, I don't see tangent constraints between the two arcs and between the line and the arc. You should always ensure tangency with a tangent constraint. Furthermore, it should be a point-to-point tangency constraint which replaces a coincident constraint.
IMO you are making it way more complicated than it needs to be by attempting to mirror two simple arcs. And you should take advantage of the Sketcher Polyline tool. It does not only create line segments but arcs too.
lemonbug
Postby lemonbug » Sat Apr 14, 2018 4:28 pm
apologies. ver 17 again. that poly line is exactly what i needed. i recall now that you showed me that a few years ago. Thanks everyone.
lemonbug
Postby lemonbug » Sat Apr 14, 2018 4:29 pm
btw, is that an animated gif? if so what tool are you using to make them. thanks
