You can download the FreeCAD file I posted and have a look at how it was done - what you want to do is a continuation of that using more cross section Sketches.
Make sure your Sketches each have the same number of segments, in approximately the same locations, for Sweep and Loft to give you the desired results. Otherwise you can end up with some really crazy shapes.
Question: I have a software package that allows me to create the Former outlines using splines etc., but in an easier way than FreeCAD.
It can export the data in DXF format - can this be imported into FreeCAD to create parts with?
Yes, with some work. IMO best would be to convert the imported geometry into sketches.
