I had seen in the error report that Kunda recommended to create it in Open Discussion so I left it there. Now I have moved it.
import of openscad file fails
Re: import of openscad file fails
small correction
when i open the scad file i remove these lines at the end of the file
this is so that openscad only creates the bracket that i'm interested in
should look like this in openscad: https://imgur.com/a/0xnJP
in freecad it looks like this: https://imgur.com/a/sinjS
if(1)
y_motor_assembly();
else
Cannot find icon: python
ECHO: "DiBond:"
ECHO: "base screw length", 16
ECHO: "frame screw length", 16
WARNING: Token 'DOT' defined, but not used
WARNING: Token 'WORD' defined, but not used
WARNING: There are 2 unused tokens
End processing CSG file
processing square007
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286419-000002.dxf
processing square008
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286496-000003.dxf
processing intersection001
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286499-000004.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-286503-000005.dxf...
drawing 5 lines...
skipping texts...
skipping dimensions...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-286503-000005.dxf
processing square004
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286637-000006.dxf
processing square005
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286638-000007.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286639-000008.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-286641-000009.dxf...
drawing 5 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-286641-000009.dxf
processing square010
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286716-000010.dxf
processing square011
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286717-000011.dxf
processing intersection002
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286717-000012.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-286719-000013.dxf...
drawing 5 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-286719-000013.dxf
processing square013
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286797-000014.dxf
processing square014
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286799-000015.dxf
processing intersection003
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286799-000016.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-286800-000017.dxf...
drawing 5 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-286800-000017.dxf
processing square025
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286843-000018.dxf
processing square026
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286844-000019.dxf
processing intersection009
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286846-000020.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-286852-000021.dxf...
drawing 5 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-286852-000021.dxf
processing square022
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286886-000022.dxf
processing square023
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286886-000023.dxf
processing intersection008
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286887-000024.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-286889-000025.dxf...
drawing 5 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-286889-000025.dxf
processing square016
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286921-000026.dxf
processing square017
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286921-000027.dxf
processing intersection006
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286923-000028.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-286923-000029.dxf...
drawing 5 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-286923-000029.dxf
processing square019
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286964-000030.dxf
processing square020
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286966-000031.dxf
processing intersection007
successfully exported c:\users\boher\appdata\local\temp\fc-00576-286967-000032.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-286969-000033.dxf...
drawing 5 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-286969-000033.dxf
processing circle003
successfully exported c:\users\boher\appdata\local\temp\fc-00576-288292-000034.dxf
processing square003
successfully exported c:\users\boher\appdata\local\temp\fc-00576-288294-000035.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-288296-000036.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-288296-000036.dxf
processing circle
successfully exported c:\users\boher\appdata\local\temp\fc-00576-288345-000037.dxf
processing square
successfully exported c:\users\boher\appdata\local\temp\fc-00576-288347-000038.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-288347-000039.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-288347-000039.dxf
processing circle002
successfully exported c:\users\boher\appdata\local\temp\fc-00576-288406-000040.dxf
processing square002
successfully exported c:\users\boher\appdata\local\temp\fc-00576-288407-000041.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-288409-000042.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-288409-000042.dxf
processing circle001
successfully exported c:\users\boher\appdata\local\temp\fc-00576-288485-000043.dxf
processing square001
successfully exported c:\users\boher\appdata\local\temp\fc-00576-288486-000044.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-288487-000045.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-288487-000045.dxf
not a freecad file: .SCAD
ECHO: "DiBond:"
successfully exported c:\users\boher\appdata\local\temp\fc-00576-321201-000047.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-321202-000048.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-321205-000049.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-321205-000049.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-321260-000050.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-321261-000051.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-321261-000052.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-321261-000052.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-321300-000053.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-321300-000054.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-321302-000055.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-321302-000055.dxf
processing circle
successfully exported c:\users\boher\appdata\local\temp\fc-00576-321355-000056.dxf
processing square
successfully exported c:\users\boher\appdata\local\temp\fc-00576-321356-000057.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-321356-000058.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-321356-000058.dxf
ECHO: "DiBond:"
successfully exported c:\users\boher\appdata\local\temp\fc-00576-331217-000060.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-331219-000061.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-331220-000062.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-331220-000062.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-331261-000063.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-331261-000064.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-331263-000065.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-331263-000065.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-331310-000066.dxf
successfully exported c:\users\boher\appdata\local\temp\fc-00576-331310-000067.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-331311-000068.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-331311-000068.dxf
processing circle
successfully exported c:\users\boher\appdata\local\temp\fc-00576-331345-000069.dxf
processing square
successfully exported c:\users\boher\appdata\local\temp\fc-00576-331346-000070.dxf
opening c:\users\boher\appdata\local\temp\fc-00576-331346-000071.dxf...
drawing 9 lines...
skipping texts...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
successfully imported c:\users\boher\appdata\local\temp\fc-00576-331346-000071.dxf
You could try loading the SCAD file in OpenSCAD and then exporting to CSG.
Then open the CSG in FreeCAD
sadly same outcome
group();
group();
group();
group() {
multmatrix([[1, 0, 0, 0], [0, 1, 0, 0], [0, 0, 1, 4], [0, 0, 0, 1]]) {
group() {
multmatrix([[-1, 0, 0, 0], [0, 1, 0, 0], [0, 0, -1, 0], [0, 0, 0, 1]]) {
group() {
group() {
group() {
group();
color([0, 1, 0, 1]) {
difference() {
multmatrix([[1, 0, 0, 0], [0, 1, 0, 0], [0, 0, 1, -17.5], [0, 0, 0, 1]]) {
cube(size = [74, 44, 43], center = true);
cylinder($fn = 0, $fa = 5, $fs = 0.5, h = 9, r1 = 11.2, r2 = 11.2, center = true);
multmatrix([[1, 0, 0, 0], [0, 1, 0, 0], [0, 0, 1, -21.5], [0, 0, 0, 1]]) {
cube(size = [43, 45, 43], center = true);
multmatrix([[1, 0, 0, -37], [0, 1, 0, 9], [0, 0, 1, 0], [0, 0, 0, 1]]) {
cube(size = [22, 44, 86], center = true);
multmatrix([[1, 0, 0, 37], [0, 1, 0, 9], [0, 0, 1, 0], [0, 0, 0, 1]]) {
multmatrix([[1, 0, 0, 0], [0, 1, 0, -13], [0, 0, 1, -39], [0, 0, 0, 1]]) {
group() {
multmatrix([[1, 0, 0, 0], [0, 0.707107, -0.707107, 0], [0, 0.707107, 0.707107, 0], [0, 0, 0, 1]]) {
group() {
cube(size = [74, 132, 43], center = true);
group() {
group() {
multmatrix([[1, 0, 0, -15.5], [0, 1, 0, -15.5], [0, 0, 1, 0], [0, 0, 0, 1]]) {
group() {
cylinder($fn = 7, $fa = 5, $fs = 0.5, h = 9, r1 = 1.93136, r2 = 1.93136, center = true);
multmatrix([[1, 0, 0, -15.5], [0, 1, 0, 15.5], [0, 0, 1, 0], [0, 0, 0, 1]]) {
group() {
group() {
multmatrix([[1, 0, 0, 15.5], [0, 1, 0, -15.5], [0, 0, 1, 0], [0, 0, 0, 1]]) {
group() {
multmatrix([[1, 0, 0, 15.5], [0, 1, 0, 15.5], [0, 0, 1, 0], [0, 0, 0, 1]]) {
group() {
group() {
multmatrix([[1, 0, 0, -26], [0, 1, 0, 22], [0, 0, 1, 0], [0, 0, 0, 1]]) {
group() {
multmatrix([[0, 1, 0, 0], [-1, 0, 0, 0], [0, 0, 1, 0], [0, 0, 0, 1]]) {
group() {
group() {
multmatrix([[1, 0, 0, 1.5], [0, 1, 0, 1.5], [0, 0, 1, 0], [0, 0, 0, 1]]) {
difference() {
cube(size = [3.01, 3.01, 100], center = true);
cylinder($fn = 0, $fa = 5, $fs = 0.5, h = 101, r1 = 3, r2 = 3, center = true);
multmatrix([[1, 0, 0, 26], [0, 1, 0, 22], [0, 0, 1, 0], [0, 0, 0, 1]]) {
group() {
multmatrix([[-1, 0, 0, 0], [0, -1, 0, 0], [0, 0, 1, 0], [0, 0, 0, 1]]) {
group() {
group() {
difference() {
group() {
group() {
group() {
multmatrix([[1, 0, 0, -30.55], [0, 1, 0, -17], [0, 0, 1, -32.5], [0, 0, 0, 1]]) {
group() {
multmatrix([[1, 0, 0, 0], [0, 0, 1, 0], [0, -1, 0, 0], [0, 0, 0, 1]]) {
group() {
group() {
group() {
group() {
render(convexity = 5) {
union() {
group() {
group() {
group() {
group() {
linear_extrude(height = 200, center = true, convexity = 2, scale = [1, 1], $fn = 0, $fa = 5, $fs = 0.5) {
group() {
hull() {
circle($fn = 0, $fa = 5, $fs = 0.5, r = 2.3);
group() {
multmatrix([[1, 0, 0, 0], [0, 1, 0, 1.15], [0, 0, 1, 0], [0, 0, 0, 1]]) {
square(size = [1.90538, 2.3], center = true);
cylinder($fn = 6, $fa = 5, $fs = 0.5, h = 8, r1 = 4.15, r2 = 4.15, center = true);
multmatrix([[1, 0, 0, -30.55], [0, 1, 0, -17], [0, 0, 1, -2.5], [0, 0, 0, 1]]) {
group() {
group() {
group() {
group() {
group() {
union() {
group() {
group() {
group() {
group() {
group() {
hull() {
group() {
group() {
multmatrix([[1, 0, 0, 30.55], [0, 1, 0, -17], [0, 0, 1, -32.5], [0, 0, 0, 1]]) {
group() {
group() {
group() {
group() {
group() {
union() {
group() {
group() {
group() {
group() {
group() {
hull() {
group() {
multmatrix([[1, 0, 0, 30.55], [0, 1, 0, -17], [0, 0, 1, -2.5], [0, 0, 0, 1]]) {
group() {
group() {
group() {
group() {
group() {
union() {
group() {
group() {
group() {
group() {
group() {
hull() {
group() {
- y-motor-bracket.csg
- (10.89 KiB) Downloaded 32 times
Are you able to produce a simpler test case with just a single "tear drop" in some solid?
Is so please post the SCAD file.
sadly no
the openscad files or not mine either
Looks like the function that creates them uses either a function called nut_trap or more likely teardrop_plus
Do you know which scad file these functions are defined in ?
Could you use grep to find out.
the nut traps are ok so i would vote for teardrop also
grep, nope i'm on windows... but i can try and look for the file anyway
