[solved]Part-design mirror of mirrored feature not possible?
dbecad
Postby dbecad » Tue Apr 17, 2018 9:17 pm
Good day,
i was trying to reproduce some geometry from another post to see if i could model it and the shape was calling for a double symmetry.
But it seems that you cannot mirror in part design WB an already "mirrored feature"? I had to use the mirror in the part WB to do it but it feels a bit broken as workflow goes.
Doing the same thing with only the mirror tool of Part WB is even more confusing as the body will suddenly appear in 2 locations in the tree and the dependency graph seems to be broken (axis & pads are outside of the body box)...
Note: I had to select both the "Body (Mirror #1)" and the "Body" to get this result. Selecting the "Body (Mirror #1)" only would only create 1/4 of the shape instead of the desired result.
So questions:
- is double (multi) symmetry feature missing from part design WB? or it's a limitation but could be added as a feature request
- is double (multi) symmetry using part WB (mirror file joined) broken?
Thanks for your help,
Cheers
OS: Windows 7
Version: 0.17.13509 (Git)
Branch: releases/FreeCAD-0-17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
OCC version: 7.2.0
mirror.FCStd
(15.16 KiB) Downloaded 2 times
Re: Part-design mirror of mirrored feature not possible?
Postby chrisb » Tue Apr 17, 2018 10:20 pm
In PartDesign you have to use the multitransform feature.
ppemawm
Postby ppemawm » Tue Apr 17, 2018 10:22 pm
This can be done with PartDesign>MultiTransform feature:
mirror_multitransform.FCStd
(18.91 KiB) Downloaded 1 time
OCC version: 7.2.0
"It is a poor workman who blames his tools..." ;)
dbecad
Postby dbecad » Wed Apr 18, 2018 12:48 am
Thanks ppemawm and chrisb, multi-transform does work beautifully.
I'll mark as resolve!
Cheers
