Ticket #3436 - Fillet crash FC daily
Re: Fillet crash FC daily
I remodeled your design so it gets more robust and uses far less operations. The clue was to model only a quarter of the top sliders and then use only one multipattern.
For external references it is sensible to use sketches instead of edges, to be seen e.g. in Sketch008. It makes the model more robust. For that it might have been better to place the XZ-plane on the top and not in the middle of the object, although I am not absolutely sure about the consequences.
Another possibility to increase robustness is the use of Expressions as seen in Sketch011. I left that with the BSpline, although I would myself have modeled this with two tangent circles of different diameters.
I replaced the other BSplines with the last two fillets. If you want something more fancy you can modify Sketch007.
One further remark: In Sketch007 you have a redundant constraint, the symmetry implies the vertical constraint. This breaks a model in later steps.
- Bildschirmfoto 2018-05-04 um 09.48.43.png (25.58 KiB) Viewed 735 times
- GoPro_cb.FCStd
- (577.97 KiB) Downloaded 26 times
Can anyone reproduce this crash on 0.18 as well ?
issue #3436
issue #3436
It still crashes in
OS: macOS High Sierra (10.13)
Version: 0.18.14957 (Git)
Branch: (HEAD detached at 22513600d)
Hash: 22513600ddc11a8d0d392f67225d443b7dc2e5bb
Python version: 2.7.15
Qt version: 5.11.2
OCC version: 7.2.0
Qt version: 5.11.2
OCC version: 7.2.0
It doesn't for me, it throws an error. And a Refine on the last feature fixes that.
OS: Ubuntu 18.04.1 LTS
Version: 0.18.14979 (Git)
Hash: 47536dcd3729d3db106af628d62f2bf449e68c49
Python version: 2.7.15rc1
Locale: French/Canada (fr_CA)
Re: Ticket #3436 - Fillet crash FC daily
I cannot reproduce this crash:
OS: Ubuntu 18.04.4 LTS (MATE/mate)
Version: 0.19.
Branch: unknown
Hash: 8ed90c858645e7562d9534265b6025d39ab4ffd6
Python version: 3.6.9
Qt version: 5.9.5
Can anybody still reproduce?
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
Yes.
I first tried with the file from the OP as it is. Opened it, selected that edge, PartDesigh fillet - object disappears, no error is shown. So I tried with a smaller fillet - selected radius field, typed "0", ",", "1". After some thinking without nothing shown FreeCAD crashed. So I opened the file again and this time first made full recompute in case some old wrongly generated geometry was the culprit. Because of tooponaming Datumplane moved and now the model was wrong. I fixed the mapping and again tried to fillet that edge - same result at setting it to 0,1mm. Attached is my modified file before the fillet.
OS: Windows 8.1 (6.3)
Version: 0.19.21575 (Git)
Hash: 85109240b5a1862d51402dfa98dd126dd6c30ca0
Python version: 3.6.6
Qt version: 5.12.1
Qt version: 5.12.1
- PhoneStand_repro_kiss.FCStd
- (72.81 KiB) Downloaded 23 times
Oops! I had just retested with success and have closed the ticket. Can you reopen it?
Cannot reproduce here. I get an error in report view on each keypress.
Version: 0.19.21329 (Git)
Hash: 2330eef823b32ac412d839031cc174353a76b013
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Same under the VM with
OS: Windows 10 (10.0)
Version: 0.19.21611 (Git)
Hash: 1ae69d2ac81bb7d2cf53af86831e0b1f8baf6a96
Python version: 3.6.8
Qt version: 5.12.6
OCC version: 7.4.0.beta
I was looking at python console instead of report view In report view I get this trying to fillet my file:
File was not written with this version of the topology
Illegal storage access...
<Exception> Illegal storage access! Please save your work under a new file name and restart the application!
0 <App> Document.cpp(3710): Failed to recompute PhoneStand_repro_kiss#Fillet: Illegal storage access! Please save your work under a new file name and restart the application!
Recompute failed! Please check report view.
Qt version: 5.12.1
Finally this is perhaps a different error which was fixed quite some time ago. Can you try to enter just zero and wait if FreeCAD crashes?
