Placement using spreadsheet values...
DAP
Postby DAP » Wed Apr 18, 2018 9:33 pm
I am attempting to create a part where part of the part is built, then it is rotated by about 15 degrees, then the rest of the part is added to it, so that the first part is at an angle to the second part. Both halves are rather complex and it would be much easier to build them square to the coordinate system.
I am trying to make this part parameterized, and to place all of the parameters in a spreadsheet. This includes the angle of the first part, and a translated position relative to the second part.
I have the first part built, and am attempting to rotate it, but I can't seem to reference spreadsheet values in the Placement dialog.
Is there a way to do what I am trying to do in FreeCAD?
sgrogan
Re: Placement using spreadsheet values...
Postby sgrogan » Wed Apr 18, 2018 9:41 pm
Use placement in the property (data tab) editor, instead of the dialog?
DAP
Postby DAP » Wed Apr 18, 2018 10:08 pm
The tip of the body is a fillet. This does not have a placement in the data tab.
In fact, even if I enter constants in the Placement dialog, it does nothing to the part.
I can translate and rotate the part if I change the body properties, but then I can't add the second part of the design to the shifted and rotated part.
Postby chrisb » Thu Apr 19, 2018 12:09 am
It would be interesting which FreeCAD version you use. Follow the "IMPORTANT: ..." link above to find out how to tell us.
Next it is very interesting which workbench you use
  • In Part workbench you change the Placement of the object created by the last operation
  • In Part Design workbench of 0.16 you change the Placement of the first sketch
  • In Part Design workbench of 0.17+ you change the Placement of the body
DAP
Postby DAP » Thu Apr 19, 2018 6:02 am
I'm using this now: OS: Linux Mint 18.3 Sylvia
Version: 0.17.13515 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Hash: e17b340949b75a226cc7d89989b0aa238ccfc75f
Python version: 2.7.12
OCC version: 7.2.0
Seems to be changing every two days at the moment.
At work, I have a version a few weeks older on Windows, but also 0.17.
If I move the placement on the body, how do I continue to add features to the body in the new coordinate system? I also need to reference features from the original body.
I have already created the object in OpenSCAD, and I am trying to recreate it in FreeCAD, so I can learn FreeCAD.
The top part is built vertically with its base at [0,0,0] It is then shifted up and tilted back, and the feet are added as a hull between a slice of the bottom of the top piece, and several disks on the x,y plane.
I have the top part built in FreeCAD, but I have been unable to figure out how to shift it, and continue to add the feet to it.
So, yes I can translate and rotate the body, but I cannot put a body inside another body, and I can't add features to the translated and rotated body without them also being translated and rotated the same amount. It is like I am working on a single piece of metal, and half way through the milling, I must remove the part from the vice, move it, and rotate before re-clamping it in the vice and continuing. I can't seem to figure out how to do this in FreeCAD.
Postby chrisb » Thu Apr 19, 2018 6:40 am
If you move the Body, of course everything inside moves as well, that's what it's all about! I cannot see any other sensible usage of a bodies placement. If you want to move things inside you can do so by changing the AttachmentOffset, which is always relative to the Body Placement.
You can use a body inside another body for boolean operations, but that is hardly necessary as we now have all these subtractive features.
DAP
Postby DAP » Thu Apr 19, 2018 7:09 am
Please tell me how to create a body that is a boolean of two other bodies. If I can do that, I can move forward.
Postby chrisb » Thu Apr 19, 2018 9:06 am
Its in the wiki: PartDesign Boolean
Tilli
Postby Tilli » Thu Apr 19, 2018 9:12 am
Hi
Not sure if it's exactly the issue you're asking about, but @NormandC helped me with Booleans.
He explained it to me directly and he also altered the relevant Wiki page to make it clearer and more accurate.
[EDIT] : and @chrisb is obviously much faster at typing than myself :D
DAP
Postby DAP » Thu Apr 19, 2018 5:43 pm
And this defeats the purpose:
"Tool bodies adopt the local origin of the active Body. If the active Body is not located at (0,0,0) in the global coordinate system, the tool bodies' placement need to be relative to the active Body. It may be easier to leave the active Body's placement at the origin before applying the Boolean feature, then to change its placement."
What I want to do is move the active body relative to a global coordinate system, and place my tools in a global coordinate system, apply the boolian and have a new body as a result. I don't see this happening if everything has to be relative to the active bodies coordinate system.
