Self centre a primitive to a Datum Plane
cram
Postby cram » Sun Apr 22, 2018 8:42 am
Trying to get my head around datum planes. I have created two one normal and is positioned along the mid point of the cylinder, the centred along the axis of origin of the cylinder circumference.
I am trying to use a subtractive primitive to remove a section of the cylinder based on these two datum plane however the result if not what I am expecting and appears to remove the whole cylinder, not just a 100mm section using the 100mm subrtractive cube used.
Version: 0.17.13509 (Git)
Branch: releases/FreeCAD-0-17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
OCC version: 7.2.0
datum_use.FCStd
(11.14 KiB) Downloaded 38 times
Re: Self centre a primitive to a Datum Plane
Postby chrisb » Sun Apr 22, 2018 9:36 am
I have problems editing/viewing your model, exact analysis has to follow. Here my guess:
The subtracitive box has no connection to the DatumPlanes, so you don't need them.
The box cuts a piece in the middle of your pad, which would yield two solids. This is not allowed in PartDesign, so one of them is suppressed.
cram
Postby cram » Sun Apr 22, 2018 11:07 am
"The box cuts a piece in the middle of your pad, which would yield two solids. This is not allowed in PartDesign, so one of them is suppressed."
I think this may be my problem. I did not know that PartDesign doesn't allow two solids
I'm a little unsure what you mean by "The subtracitive box has no connection to the DatumPlanes, so you don't need them."
When I created the subrtactive box I chose to use attachment to DatumPlane and DatumPlane001?
Postby chrisb » Sun Apr 22, 2018 11:21 am
Ok, I see. I had problems with viewing the details of your file and still have them when I try to change something.
DeepSOIC
Postby DeepSOIC » Sun Apr 22, 2018 12:17 pm
I have them too.
There is something horrily broken about Box:
>>> App.ActiveDocument.Box.Placement
Placement [Pos=(-2.5e+099,-5e+099,-2.5e+099), Yaw-Pitch-Roll=(153.435,-3.18055e-015,65.9052)]
It is placed in the infinity. How does it happen, I wonder...
EDIT: Ah, I see how. It happens when you use Inertial CS attachment on datum plane. Datum plane is internally infinite, and this bogus result is the outcome.
DeepSOIC
Postby DeepSOIC » Sun Apr 22, 2018 12:42 pm
NormandC
Postby NormandC » Sun Apr 22, 2018 5:13 pm
Hello cram,
A few nasty bugs crept up in the initial 0.17 release, they have been fixed, so I recommend you download and install the latest version 0.17.13515.
Download
cram
Postby cram » Wed Apr 25, 2018 9:04 am
Hello cram,
Download
Ok NormanC , thank you will do so.
alberich
Postby alberich » Wed Apr 25, 2018 9:51 am
Hello cram,
Download
The Download page refers to 0.17.13519. Also, the linux appimage is still at .13509. Is that correct?
Postby chrisb » Wed Apr 25, 2018 1:17 pm
Both are correct. Three days ago Normand was correct as well.
