Split solids into 2 or more parts
Edgar3500
Postby Edgar3500 » Sun Apr 22, 2018 1:20 pm
Hello everyone, how do I do if I want a piece in 2 or more parts but keeping all?
With the Boolean method you copy or clone the piece and subtract a part in the original piece, and then subtract the other part in the copied piece.
For example, in other programs a cutting plane can be defined and both parts remain.
The original post of this subject is in Spanish Forum.
microelly2
Re: Split solids into 2 or more parts
Postby microelly2 » Sun Apr 22, 2018 1:24 pm
You have in Part -> Split -> Booelan Fragments
DeepSOIC
Postby DeepSOIC » Sun Apr 22, 2018 1:35 pm
Part Slice
EDIT: To get the solids apart parametric, you can also use Compound Filter, which is buried in Part menu. Or, use Explode Compound tool from Lattice2 add-on workbench.
freecad-heini-1
Postby freecad-heini-1 » Sun Apr 22, 2018 1:51 pm
Part Slice
Compound Filter. Please can you describe how to reach the same result as Lattice2 explode.
DeepSOIC
Postby DeepSOIC » Sun Apr 22, 2018 2:04 pm
1. Select Slice object, apply Compound Filter.
2. Select CompoundFilter object, go to properties. Switch Filter Type to "specific items".
3. In 'items' property, type a zero.
-> this is your first solid.
4. repeat for however many solids you need to extract, increasing the number you type into 'items' for each step.
Postby NormandC » Sun Apr 22, 2018 5:47 pm
Usage question, should have been posted in "Help on using FreeCAD" forum.
But I am the only one here who cares about it anyway. :roll: :roll: :roll:
freecad-heini-1
Postby freecad-heini-1 » Tue Apr 24, 2018 1:58 pm
Thank you so much Viktor.
Postby chrisb » Tue Apr 24, 2018 11:12 pm
Can I move the solids separately?
With the german locale I have a problem with the list, perhaps because ',' is the decimal separator. If I write '0,1' I get an error, I have to use the range instead. The range behaves peculiar as well:
I have an object, which I have sliced in two. Entering the values below yields the following results
items: 0 -> result: first part
items:1 -> result: second part
items: 0:1 -> result: first part
items: 0:2 -> result: both parts
Postby chrisb » Tue Apr 24, 2018 11:14 pm
There seems to be no entry for Compound Filter in the wiki. Or did I miss it?
DeepSOIC
Postby DeepSOIC » Tue Apr 24, 2018 11:22 pm
You should be able to. It's the same CompoundFilter as in Lattice2. I think bernd transferred it, don't quite remember...
That shouldn't be a problem, we have it so here in Russia as well.
See https://github.com/DeepSOIC/Lattice2/wi ... lter#items for what it's supposed to be. I'll check...
