Designing simple organic shapes
kefir
Postby kefir » Sat Apr 28, 2018 11:27 am
I'd like to learn if it's possible to use freecad for simple (or complex) organic shapes. For example, something like this:
Where would I start to do design something like this in freecad? I'm talking about the basic "organic" shape of this lure's body, not the hooks and eye screws.
dbecad
Re: Designing simple organic shapes
Postby dbecad » Sat Apr 28, 2018 2:02 pm
Good day Kefir,
you should have a look at the video on how to model a hook (kind of appropriate :D ) by Christoph here:
https://forum.freecadweb.org/viewtopic. ... 2&start=10
It's more of an organic shape than a hook, you will have to use sweeps and lofts, body first then add the eyes (maybe separate body)
Cheers
Postby chrisb » Sat Apr 28, 2018 2:55 pm
The product design tutorials may give you an idea of the possibilities. The bottles might be interesting.
NormandC
Postby NormandC » Sat Apr 28, 2018 6:20 pm
Organic shapes are actually hard to model in CAD. FreeCAD is more geared toward mechanical design, although its underlying geometric modeling kernel supports it, the required advanced surface tools are not all fully exposed yet in the GUI. That being said you may be able to do what you need with the mentioned approaches.
It's much easier to model organic shapes in polygon modeling.
bejant
Postby bejant » Mon Apr 30, 2018 1:42 am
Hi, still pretty much the same as when you asked back in 2014:
https://forum.freecadweb.org/viewtopic.php?f=3&t=7131
This time your model will be a lot simpler...
kefir
Postby kefir » Mon Apr 30, 2018 9:26 am
Wow, I literally asked the same question 4 years ago. The internet has a better memory than me. I guess it's time to look more into mesh design for stuff like this, as long as nurbs or something like that isn't really an option.
ulrich1a
Postby ulrich1a » Mon Apr 30, 2018 10:15 am
Have a look at the Surface Workbench: https://www.freecadweb.org/wiki/Surface_Module
I tried to model an organic shape with this tools. My experiences are mixed. I set up a frame made of connected sketches and filled surfaces into this framework. The results are not always as good as I wanted, but something is doable. Be prepared to safe often, as I experienced some crashes.
Ulrich
thschrader
Postby thschrader » Mon Apr 30, 2018 11:49 am
Not easy, but possible.
See the post from hammax (snail-shell):
https://forum.freecadweb.org/viewtopic. ... 4&start=30
and
modelling acoustic-foam:
https://forum.freecadweb.org/viewtopic.php?t=26260
