Can't rotate, move or pan
Leatherman
Postby Leatherman » Tue May 01, 2018 10:55 am
Hello
since today I'm unable to rotate, move or pan anything. Simply the commands with the mouse doesn't work and that in all style navigation options. I'm using a wireless mouse as well the touchpad from my laptop, nothing works. I've forced an upgrade today, but that also didn't help.
Someone has an idea please?
OS: Ubuntu 16.04.4 LTS
Version: 0.18.13638 (Git)
Build type: None
Hash: 983f2472a871f8b808fccdf8fa8d05dd276c3fba
Python version: 2.7.12
OCC version: 7.2.0
Locale: English/India (en_IN)
Re: Can't rotate, move or pan
Postby chrisb » Tue May 01, 2018 12:03 pm
If you have already tried different mouse models it is not very likely to help, but you can try deleting or moving your config files. Please note that you will have to configure the mouse model again.
Leatherman
Postby Leatherman » Tue May 01, 2018 12:49 pm
no, unfortunately that did not work either. Is this a rather unusual problem, didn't find anything in Google?
Postby chrisb » Tue May 01, 2018 4:06 pm
Yes, it is unusual. I have seen the mouse model changing all of a sudden, but nothing else in this direction.
Here is what I would try next, but it is in fact only guessing
- Have you checked that the config files are newly created after you deleted them?
- reboot computer
- do the icons for different views work?
- does the panning work with normal mouse? Perhaps the battery is low and keep mouse down plus movement doesn't work
- check free memory with command free
- check free disk space
- install old 0.16
- install appimage
- write log file
